1993 Civic DX Surging Issue please help
Old May 20, 2011
kbrassfi's Avatar
kbrassfi is an unknown quantity at this point
Unhappy 1993 Civic DX Surging Issue please help
Well my car began to lightly surge Sunday, didnt drive much on Monday Tuesday still was surging slightly but would go away when gave the throttle, mostly seems to happen during acceleration but seems to be getting worst, by Wed on way into work car was surging then died on highway, I towed home and replaced ICM and still no spark, replaced coil and started, however still am having surging issues and afraid was not the coil but the cause of the coil failure rather. I have done my searching and have found these to be the most common issues, but have spark now but still seems to miss getting worst regardless of temperature, etc happening at different speeds now instead of just at range was before, but before I pour anymore money into the issue I was hoping to get a jumping off point to start and maybe see if anyone local in San Diego with 1.5 that I can try Dizzy from to see if is just my whole dizzy unit, or if something else and go from there...
Thanks for all the help!
Old May 20, 2011
lazlong's Avatar
Re: 1993 Civic DX Surging Issue please help
Most of the guys I have seen with this problem ended up replacing the distributor housing also. #4: http://www.hondapartscheap.com/south...t=0&quantity=0
Old May 21, 2011
kbrassfi's Avatar
well unfortunately it wasnt the distributor, so back to square one, bleh! well anything else I might try would be helpful, tested compression no major variances, rechecked all sparkplug gaps, and temp sensor seems to be giving correct readings and rising as always had on dash, I dont know where else to look please help!
Old May 22, 2011
HommeDeBois's Avatar
HommeDeBois is an unknown quantity at this point
Try your timing belt. Mine was doing something similar and when I finally got it checked out, my timing belt was off by 3 or 4 teeth. The tensioner was shot and the belt had slipped out of adjustment. See if that helps
Old May 23, 2011
kbrassfi's Avatar
ok, so here is where I stand after weekend working with online tech, problem would seem to correct, then come back, read below
Status:Awaiting Expert ReplyCategory:HondaValue:$27
SMS Text Alerts
Asked by you on Saturday, May 21, 2011 9:21 PM EST
0 Accepts / 1 Answered Question
I have a 1993 Honda Civic, it has been surging while driving, started out lightly at first but then as started getting worst my coil went out, replaced and got spark again but problem has been getting progressively worst now not just driving happens while idling too, have plenty of coolant and sensor seems to be rising on guage as normal to normal operating temperature. I tried a new distributor even and still have same issue, need help of where to look next, btw compression from 1-4 170, 160, 165, 165 any ideas? cant afford to keep throwing money at problem hopefully can return distributor
Country: United States
Make: Honda
Model: Civic
Year: 1993
Engine: 1.5l sohc 16 valve
Already Tried:
ICM, Coil, Distributor, battery, battery connections, resetting ecm
Edit Price
Expert
You have received an Answer!
From master tech
Sunday, May 22, 2011 1:18 AM EST
master tech : Hello welcome to just answer I am master tech and will be able to assist you today.
JACUSTOMER-gicf9kyb- : ok
master tech : on this motor their is a fast idle valve if you remove the 2 screws and the gold color plate. you will see a plunger gently screw this back down until it stops then reinstall the cover and the 2 screws. then readjust the idle if needed.please CLICK HERE for fast idle valve location and info
master tech : CLICK HERE
master tech : Hello
JACUSTOMER-gicf9kyb- : I just received response opening window for location now
master tech : ok
master tech : this is very common
JACUSTOMER-gicf9kyb- : Im looking for picture of gold plate now not seeing where location would be
JACUSTOMER-gicf9kyb- : but do see where valve itself is so should be able to locate
master tech : this is under the throttle body
master tech : it's in a tight spot
master tech : most people just remove the throttle body and it makes this job much easier
JACUSTOMER-gicf9kyb- : I was just going to ask that
JACUSTOMER-gicf9kyb- : I will have to do this once daylight is out again
master tech : im one step ahead of you lol
master tech : sure thing.
JACUSTOMER-gicf9kyb- : ok, so if that does not work, would that mean would need to replace?
JACUSTOMER-gicf9kyb- : or?
master tech : yes but in my years these are able to be readjusted back to normal and all is good
JACUSTOMER-gicf9kyb- : ok, like said once have daylight will do and get back to you
master tech : ok sounds good.
JACUSTOMER-gicf9kyb- : Im keeping my fingers crossed is that simple
master tech : have a nice evening let me know tomorrow how this goes.
JACUSTOMER-gicf9kyb- : because I have been at a loss
JACUSTOMER-gicf9kyb- : thank you will do
master tech : yes I have seen that
master tech : good night
JACUSTOMER-gicf9kyb- : ok, well did what suggested, when first started car seemed worst than before then slowly seemed to get better as car warmed up, once car was warm I turned off, pulled ECU fuse and set ecu at idle with all accessories off for 20 minutes
JACUSTOMER-gicf9kyb- : I turned off vehicle and restarted the vehicle, and seemed fine still, took out for a drive to test if fixed issue, seemed better at first then slowly got worst and by time got off freeway again was surging in idle again where felt like was going to die then kick back up and on
JACUSTOMER-gicf9kyb- : Another note not sure if helps or not but seems to lack power and when get on the gas when is happening engine revs high without getting much response in speed then seems to kick so to speak
JACUSTOMER-gicf9kyb- : I am disappointed wasnt as easy as the adjustment, just my luck lol
master tech : Good morning
master tech : let do the test on the fast idle valve.
master tech : did you actually unbolt the fast idle valve from the throttle body ? the reason Im asking is their is a oring that will some times fall off.
JACUSTOMER-gicf9kyb- : no I didnt remove from the Throttle body
master tech : ok then lets follow the test that I posted last night and see what the results are. was the plunger loose ?
JACUSTOMER-gicf9kyb- : Plunger did seem like needed a lot of adjustment down but did not remove throttle body to adjust since did last night
master tech : ok. lets do the test then
master tech : the fast idle valve might be bad
master tech : these do get carbon on the plunger and will sometimes keep the valve open
JACUSTOMER-gicf9kyb- : test is is the right side of what sent me last night right? feeling hole on inside of throttle body?
master tech : yes correct
JACUSTOMER-gicf9kyb- : will let you know results
master tech : sounds good
JACUSTOMER-gicf9kyb- : ok, so made sure again that round piece around plunger was in fact tightened down again in the day light, which it was, I checked over everything once again and started engine, I felt a suction from lower port as car engine warmed I continued to test and felt suction from lower port
JACUSTOMER-gicf9kyb- : I felt light suction from metal tube from valve cover to Air Intake duct, heavy suction from upper port that if covered would start to die, which seemed to check out normal, checked valve on upper radiator hose wasnt any air in the line, did notice maybe a small amount of coolant leakage from older hoses, etc but coolant levels were all normal, and no air in the line that I noticed
master tech : so after this warmed up you should not feel the suction. so sounds like a bad fast idle valve then if you did the test correctly
JACUSTOMER-gicf9kyb- : yea, made sure to follow correctly, tested at start up, allowed to warm until fan kicked on, then tested again, as test said to verify no air in coolant system
master tech : ok sounds like the issue is the fast idle valve.
master tech : I have seen people actually take these apart and clean them.
master tech : I seen this on you tube but have never actually done it.
master tech : we dont do this at the dealer once we confirm a failed part we recommend a new part.
JACUSTOMER-gicf9kyb- : ok, I am looking for part now, hopefully not too expensive LOL I would rather put new one on since this is not a part I am familiar with on vehicle
master tech : Ok these are around
master tech : 150 at the dealer
JACUSTOMER-gicf9kyb- : ok, thats not horribly priced compared to what was expecting, my dizzy unit from Autozone cost more
JACUSTOMER-gicf9kyb- : ok, so looking for part online, can not locate, is dealer typically only place to find New? also saw while searching instead of cleaning a lot of people who just replaced Plunger is there a place to obtain plunger without using one from a used one?
master tech : No their is not parts sold for these only the valve its self. The dealer is the only place that sells this to my knowledge
JACUSTOMER-gicf9kyb- : ok, thats what it was looking like when looked online, should I discontinue driving my car while this is happening until can resolve issue? I do not want to do any damage that would cause more issues
master tech : No you can drive it nothing else will get damaged.
JACUSTOMER-gicf9kyb- : ok, thank you
Please Do not click "ACCEPT" until your Happy with the answer. Please take a moment and leave me some "FEED BACK" as it's greatly appreciated."BONUSES" are nice too.
Expert
Your Expert needs more information
From master tech
Sunday, May 22, 2011 2:54 PM EST
What Happens Now?
Your chat has ended, but you can still work with your Expert to get an answer to your question if you have not yet received one.
Come back to this page at any time to see additional information from your Expert. You will also receive an email when your question is updated. If you want to send a message to your Expert, use the box below.
If you have already received a satisfactory answer to your question, click the Accept button above. Experts are credited for each accepted answer they provide.
Expert
From master tech
Sunday, May 22, 2011 4:55 PM EST
your very welcome.
please take a moment to leave me some feedback after you accept. I strive for all positive feedback and bonuses are always welcomed.
Master Tech .
I don't receive credit for my work until you click the accept button.
You replied
Sunday, May 22, 2011 5:36 PM EST
well I took off FITV in meantime while awaiting a dealership parts dept to be open, it was actually fairly clean, seemed like a bit of corroded coolant on it, cleaned up and tested with lighter, plunger went down, but know what felt when tested and that was air suction still, I checked the IAC valve as well and screen was pretty dirty, cleaned up and reattached, still was acting up slightly while warming up, once all the way up to temp, turned off car, unplugged ECU fuse for a little bit, not terribly long, and when reattached and turned on the car while warm was dipping almost dying on a 4th count almost, but know engine turns incredibly fast so not like a loss of spark was like deh-deh-deh-wom deh-deh-deh-wom etc. unplugged ECU fuse currently for longer to see if will help. I did notice around thermo that radiator hose was dripping a little bit but very little not a spray or anything like that, I do believe the thermostat to be removed as just bought recently but temp never seems to go as high as my fiancees integra so not sure if this would cause issue that if temp not raising high enough wouldnt enter computer into correct programming for air, etc
Expert
From master tech
Sunday, May 22, 2011 5:51 PM EST
hmm im lost a little
so now this is cleaned up but the car still leaks at the bottom port and now it starts funny and is leaking coolant ?
You replied
Sunday, May 22, 2011 6:10 PM EST
well its not leaking major coolant, just noticed little bit when took apart, just reset ECU again and warmed up perfect with no issues, but while warm felt bottom port and could still feel suction (hot as hell too lol) but no dips in idle etc so now turned off and letting car cool back off to see if problem reoccurs while cooled down or...
Expert
From master tech
Sunday, May 22, 2011 6:17 PM EST
so if you block the port with your finger you can control the idle?
You replied
Sunday, May 22, 2011 6:19 PM EST
no, doesnt change anything, what I was saying was that even though can still feel suction Idle feels fine now, but letting car cool down to see if reproduces itself
Expert
From master tech
Sunday, May 22, 2011 6:21 PM EST
h mm odd.
did you readjust the idle ?
You replied
Sunday, May 22, 2011 6:23 PM EST
no I did not change idle at all, seems to be idling at same speed as normal, I do not have an internal rpm range as no tach with Automatic,
You replied
Sunday, May 22, 2011 7:47 PM EST
so after I had "reset ecu" at least I think ran at idle perfect for awhile, then let car cool off for over an hour went inside, came back and turned on car still was idling fine, went out for a drive, felt fine at first like when first made adjustment on backside of FITV then progressively got worst again, a new symptom though, again when I got to autoparts store to return dizzy (where I took test drive) when put in park seemed like Idle was searching again also did in neutral however when in drive was different type sputter I dont know if did not reset ECU properly because problem seems to correct itself and feel fine while driving then slowly return to previous condition although does feel better than did. Still presents itself the worst when under load trying to go uphill, as throttle changes, but at idle seems to steady self, please help know on right track since everytime mess with throttle body stuff begins to feel better then return to previous state
Expert
From master tech
Sunday, May 22, 2011 9:06 PM EST
well heres the deal after you reset the ecu you have to do a idle relearn.
so lets start at step 1
reset ECU
#2 perform idle relearn and adjust idle to specs and retest with OUT resetting the ECU
CLICK HERE for idle adjustments
Idle Learn Procedure: When
and How to Do It
All Honda models with programmed fuel injection
(PGM-FI) have the ability to learn and adjust the
engine idle speed to optimize engine idle
characteristics.
The idle learn procedure should be done
whenever you do any of these actions:
  • Reset, replace, unplug, or reprogram the ECM/
PCM
  • Disconnect or replace the battery
  • Do engine work that requires R&R of the
intake manifold or the throttle body
To allow the ECM/PCM adaptive idle speed
system to learn and adjust the engine idle speed,
here's what you do:
  • Make sure all electrical items (A/C, audio unit,
defogger, lights, etc.) are turned off, then start
the engine.
  • Let the engine reach its normal operating
temperature (the cooling fans cycle twice; the
coolant temperature is about 194° F).
  • Let the engine idle for at least 5 minutes with
the throttle fully closed and with all electrical
items turned off.
  • If the cooling fans cycle on while doing an
adaptive idle learn, add the time the cooling
fans are on to the 5 minute adaptive idle learn
time.
You replied
Sunday, May 22, 2011 9:50 PM EST
ok, so that is essentially what I had done, was warming up fine, did have a little bit of stumble like before but not really that bad, then when car reached normal operating temp started doing that idle bump like was dying when was in park/neutral and CEL light came on when would turn on A/C the problem would stop, however even if driving with A/C on decided to see if this would help issue since seemed to stop erratic idle in park/neutral and it did not still felt like was a lack of power like was starved for air/fuel/spark something... how do I test CEL code to see what is showing, I have had no CELs until today when took IAC off TB and cleaned screen, is this a result of needing a ECU reset or are both things FITV and IAC bad, etc please help as I would like to resolve asap and I know you are tired of hearing from me lol
Expert
From master tech
Sunday, May 22, 2011 11:35 PM EST
wow you got a few issues going on here.
this might need a hands on tech to proceed further.
You replied
Monday, May 23, 2011 12:10 AM EST
well came on all of a sudden, and progressively got worst, will seem to be better then as start to drive gets off again, so wondering if I have a vacuum leak somewhere that would cause these issues, if have to will take in for a diagnosis and go from there, just hate to pay someone to do the work part when I can do myself, but at this point the diagnosis part is where I am stuck, I'm hoping not both the FITV and the IAC are bad
Old May 23, 2011
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
I went through this almost exact same problem (without the heavy surging you started with) I replaced the FITV and that fixed the surge when cold but still had the surge when warm. Cleaned the IACV and it got worse. Replaced that and the surging issues went away.
Sill have a starting issue but the car runs perfect once it starts.
Old May 23, 2011
kbrassfi's Avatar
timing belt fine, just checked no missing teeth no cracks, no looseness, same issues still
Old May 23, 2011
lazlong's Avatar
http://check-engine-light-codes.blog...retrieval.html
Old May 23, 2011
kbrassfi's Avatar
code went away before could test it, so not sure what code was showing, ordered my FITV to see if helps on low end, and then go from there, I am going to flush my radiator too, to just make sure again that there is no air in the system. Once go to auto store and pick up some more TB cleaner will spray around intake to check for vacuum leaks
Old May 26, 2011
Well, when you figure it out, be sure to post back here and let us know, and for future reference of anyone with a similar problem
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
McD
Apr 29, 2015 03:50 PM
Civicman92296
Apr 23, 2015 09:22 PM
civic_gt
Apr 19, 2015 08:15 AM
skywalker
Nov 8, 2001 05:04 PM
