I hydrolocked my engine and fixed that part. now something eletrical?
Old May 1, 2011
manonthemoon299's Avatar
manonthemoon299 is an unknown quantity at this point
Exclamation I hydrolocked my engine and fixed that part. now something eletrical?
As the title says i hydrolocked my stock d15b8 with an intake, i tried starting it like 20 times after it happened cause i was not thinking. After i got it home i took off the intake, took out the plugs and vacuumed out the water, i tried turning it over by the harmonic balancer and it stopped turning and now it only goes back and fourth like an inch both ways. MY starter was messed up and i got a new one, got new plugs put it all back together, now if i try and start it the starter is just spinning around, it doesnt seem like the engine is getting spark or something. Any one know what could be wrong?
Old May 1, 2011
MelJ's Avatar
Trance Addict
Re: I hydrolocked my engine and fixed that part. now something eletrical?
If it stops turning when you rotate it, you've bent the valves.
Old May 1, 2011
BlueEM2's Avatar
Whachya lookin at?
Yea your internals are probably all messed up. You need to take the timing belt cover off and see if your timing is still correct before you crank that engine any more.
Old May 1, 2011
as others said, taking the water out is not all...
most likely bent valves and other sutff. for other stuff you need to open the engine to know what.
Old May 1, 2011
So turning it like i did messed it up?
Old May 1, 2011
BlueEM2's Avatar
Whachya lookin at?
That depends on what the timing belt did when it hydrolocked. You may have been lucky and everything is okay... you need to check the timing. Also, sucking the water out does not unseal the pistons from the cylinder walls... You might need a new engine
Old May 1, 2011
MelJ's Avatar
Trance Addict
That itself didn't do any damage. When the pistons are moving, there shouldn't be any resistance. They're being restrained by something, which like the others said, requires further internal investigation. I've got my fingers crossed for you though. My friend drove through a tiny puddle and completely destroyed his car
Old May 2, 2011
^ ^^ Yup! need to open to find out
Old May 3, 2011
Yeah bent valves :/ Theres a guy on craigslist that is selling the same motor as mine for 175. Ive never swapped an engine. But since its the same how hard is it going to be? What am i going to have to do to do this? And can i keep the tranny mounted on the car and just take the old out and put the new in?
Old May 3, 2011
mac25's Avatar
Dr Krieger of Modification
if it's the valves can he just replace the head, and not the full engine block? but 175 sounds good.
Old May 3, 2011
yeah ill see, but I doubt he would, even if I bought the whole thing
I could still just take the head off, but since water got in the engine I should probably just swap it.
Old May 3, 2011
BlueEM2's Avatar
Whachya lookin at?
You could just change the head but you need to make sure the pistons which came in contact with the valves are okay... that and it's easier to just change the engine sometimes.. It's WAY easier to pull the tranny out when replacing the engine.. You can't leave just the tranny in unless u leave it jacked up somehow.. just not worht it.
Old May 3, 2011
and be sure to do timing belt before dropping the engine in! and compression test before buying
Old May 3, 2011
How do i do a compression test if the engine isnt hooked up? Just hook up the starter to a battery?
Old May 3, 2011
Also, Could my engine just not spin anymore by me turning it cause the timing is way off? Cause i think i hooked my spark plug wires up wrong. And i dont know if that can mess the timing up once it trys to start or something.
Old May 3, 2011
MelJ's Avatar
Trance Addict
I don't think mixing up the wires is going to be detrimental once you get everything back together. Your engine won't spin anymore because like I said, the pistons are contacting the valves. It won't go any further because the car went out of time once the water got in the engine. You should really invest in a manual or check for a pdf file for one.
Old May 5, 2011
So i am taking off the belt cause i guess its out of time before i buy this engine since this might only be what it is. Im stuck on taking the crank pulley off. How do you hold the flywheel down so you can loosen it. Or is there another spot you can hold down or something?
Old May 5, 2011
BlueEM2's Avatar
Whachya lookin at?
I thought you said it bent valves? If the timing is out it probably did bend valves... You may however get lucky!
Old May 5, 2011
MelJ's Avatar
Trance Addict
I believe Amazon sells an official or something VERY close to the Honda style crank pulley removal tool.
Old May 5, 2011
Let me rephrase that.
If at all possible, try to get an engine that the seller can tell you what the compression was before he pulled the egnine off. more ease of mind
shindrome
Exterior
May 5, 2015 02:50 PM
McD
Apr 16, 2015 10:46 AM
supercivic01
South
Nov 30, 2001 11:27 AM
