Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Engine swap
Old Jul 3, 2023
justnsss's Avatar
justnsss is an unknown quantity at this point
Engine swap
I’m planning to k swap my ek civic but I haven’t done a full swap before. I found another d16y7 for under 500 and I was wondering if it’s worth buying it to swap the same engine out for some practice?
Old Jul 3, 2023
Re: Engine swap
k-swapping vs swapping in a D16 are going to be completely different beasts. A straight 1 for 1 swap is going to be exponentially easier than swapping in something that never came in that chassis. Sure, swapping in a D16 will give you pulling and re-installing an engine, but when you get to the k-swap, you're going to run into (potentially) so many more obstacles. Might as well save the money, do the research of what it'll take to k-swap, then just go for the k swap right off the bat. Work slow and deliberately, no need to rush it. Do that and make sure you have everything you need and you'll be fine, so long as you're committed to the swap
Old Jul 3, 2023
GolNat's Avatar
Prelude Owner
Re: Engine swap
Is it your primary vehicle? Plan on it being down for a bit
ceiling_fan2099
Engine Swaps
Jun 30, 2023 06:19 AM
revs28g
Jul 9, 2008 11:28 AM
cj2185
Engine Swaps
22
Aug 10, 2005 03:40 PM
eviLsliDinciVic
Engine Swaps
Nov 7, 2003 07:11 PM
speed werx
Feb 13, 2003 09:44 PM
