Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
Please Help, On This Engine
Old Feb 16, 2011
supremeberto's Avatar
supremeberto is an unknown quantity at this point
http://s1182.photobucket.com/albums/x448/supremeberto/
Does Anyone Know What Kind Of Engine Is This, I Know Its A Vtec But Not The Model Of It ! Please Help !!
Old Feb 16, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: Please Help, On This Engine
looks like a d16y8.
Old Feb 16, 2011
Originally Posted by Newfiedan
looks like a d16y8.
Hmm Thanks Man !
Old Feb 17, 2011
Newfiedan's Avatar
If you can see it in person the model is stamped on the block where the trans meets the engine, d16y7 non vtec block, d16y8 vtec block. Some ppl put the d16y8 head on the d16y7 block for what is called a minime swap. Gives about 135 hpish with that combo problem is that unless the bottom end is built up a bit they tend to be hard on the bottom end due to the higher compression sometimes to catastrophic results (breaking the bottom end). I have the d16y8 head sittin in my garage in very good shape but opted to not so the swap for this reason.
Old Feb 17, 2011
Ek787's Avatar
wildchild787
Ek787 is an unknown quantity at this point
it could be a d16z6
Old Feb 17, 2011
Thanks guys I appricate your help because I'm buying a 92 civic and he said he swap it for a 99 vtec which is that picture I showed you guys. But hopeffully he can find out because I need to buy a caamshaft for it and I need too know the model of that engine.
Old Feb 18, 2011
BlueEM2's Avatar
Whachya lookin at?
Get him to check for you, its stamped on the block.
Old Feb 18, 2011
So if I was too check it exactly where that orange block is there should be the model stamped there right? And is maybe on the sides of the block ?
Old Feb 19, 2011
Newfiedan's Avatar
it is stamped right on the block where the transmission meets the engine, its not hard to see and its pretty clear.
Old Feb 21, 2011
rhondamera's Avatar
rhondamera is an unknown quantity at this point
I have a d16y7 and would like to do a few mods (i know there aren't many) and right now i have an injen short ram and a pacesetters catback exhaust. That is 'bout all i can do to keep in california legel however, i will be heading to arizona in few months. i noticed on one of the relpies mentioned switching the head to a y8 head....however you need to build up the bottom end....well.....what do you mean by bottom end?
Old Apr 9, 2011
Zcuda's Avatar
Zcuda is an unknown quantity at this point
Bottom end being the Crank, rods & Pistons (W/ rings)... heavier duty to handle the higher compression. Now specifically what type to use... that I don't know.
Old Apr 9, 2011
lazlong's Avatar
Unless the '99 was a swap it isn't a ZC. They didn't make ZCs in '99.
Engine code is in the same place on every engine:
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
