Engine Performance Modifications Post information/questions about Forced Induction, Nitrous, Engine Building and Swaps here.
$4000 turbo civic, how fast
Old Oct 8, 2007
paynetrain's Avatar
paynetrain is an unknown quantity at this point
Hi everyone, I'm new to the forum but am looking at buying a 1997 civic hatchback with 170k for $4000, I'll probably pay somewhere around $3500. I was wondering how much hp you think these mods would add as well as how fast it would run 1/4 mile time.
It has a t-25 turbo, 450cc dsm injectors, p06 uberdata (What exactly is that?) rfl blow of valve, front mount intercooler, magnaflow exhaust/ great down pipe, CAI, z6 si tranny, 6 puck clutch , and a greddy turbo timer.
It also comes with a z6 head and two bare soch blocks, what the heck are those?
Thanks for your help guys.
-Nick
Old Oct 9, 2007
Aly's Avatar
Aly
Aly is an unknown quantity at this point
Re: $4000 turbo civic, how fast
I'm no expert, but I wouldn't touch that car.
Old Oct 9, 2007
speedfoos's Avatar
As long as the car isn't beat to ****, that's actually a pretty good setup. The "two bare soch blocks" are two spare SOHC (single overhead cam) engine blocks, and it sounds like he's giving you a spare cylinder head as well.
P06 is the code for the ECU in it and Uberdata is the programmable ROM chip that allows someone to tune the car for boost.
All this being said, this car will take some know-how to maintain and keep it in optimal running condition. Oil changes at least every 2000 miles because of the turbo, the clutch will be a lot different than you're used to. It will wear faster and also be more difficult to drive. Hopefully it's a spung 6-puck, vice a straight 6-puck. Makes it easier to get going from a stop.
Make sure it idles properly, doesn't throw any Check Engine Lights (CELs), and is solid under boost all the way to redline before you sign a check and take possession of the car. If not, you're in for a $3500 migraine...
Old Oct 9, 2007
Alpha 5's Avatar
If it all checks out sounds like a good deal BUT (and this is a huge BUT) it sounds like you do not have the know how to keep it maintained. Turbo cars are cool and all but (once again) they are high maintenance. Kinda like dating a model, you can brag about sleeping with her and show her off but the trips to Maui ain't cheap!
Old Oct 11, 2007
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
Originally Posted by speedfoos
Oil changes at least every 2000 miles because of the turbo,...
How do you figure?
Old Oct 11, 2007
HighBoost's Avatar
HighBoost is an unknown quantity at this point
Old Oct 12, 2007
speedfoos's Avatar
<sigh> In the interest of not "jumping down anyone's throat"....
By adding a turbo - a serious heat/engine stress/oil-consuming device that you've just spent upwards of $4000 on - you will simply wear the oil out faster. You will be driving the car harder as because boost is fun.
By this your maintenance category jumps up to 'Severe' and it's worth the extra $s to do oil changes more frequently. This is not a factory turbo setup on a car that's designed for it. We strap these on cars that aren't made for it and make them work. Take the extra step by doing more maintenance so you don't blow up your new toy.
Old Oct 12, 2007
I'm running synthetic oil in the Cummins and am changing oil at 15,000 mile intervals. I'm willing to bet it is much harder on oil then any little four-banger is. It regularly sees 1300*F EGTs and more soot in a day then your Civic'll see in a lifetime.
That being said...yes you are prolly talking about conventional oil. And yes, diesel oil is different, but 2k miles is excessive...
Old Oct 13, 2007
speedfoos's Avatar
That's fine. I'm sure your diesel - which is designed for the turbo that's on it - is doing perfectly well with your maintenance schedule.
My little turbo'd four-banger - which is not designed for the turbo that is on it - will continue to get oil changes at every 2000 miles with synthetic oil. Better safe than sorry.
ChristinaVHH
May 10, 2015 03:51 PM
hokiedad4
Apr 30, 2015 07:18 AM
cloudguy
Apr 28, 2015 05:02 AM
tylerginevan
Apr 27, 2015 12:29 PM
vtechcivic
Apr 21, 2015 06:58 PM
