lowering 97 civic
Old Mar 4, 2010
civic0918's Avatar
civic0918 is an unknown quantity at this point
lowering 97 civic
right now with my budget i can either get eibach sport line 1.8 inch drop or a set of adjustable coilovers with strut that are used. Which ones should i go with and how low should i go? I just want it too look good little to no gap with a 17 inch wheel and 205 40 series tire. please give me some ideas on how far to drop it thanks alot.
Old Mar 5, 2010
civic0918's Avatar
Re: lowering 97 civic
i can get these for 150 do they look pretty good like they will do the job please help id like opinion tonight im ordering in the morning just hope i choose the right ones please help any info would be great
Old Sep 24, 2011
supraman1990's Avatar
supraman1990 is an unknown quantity at this point
i would hands down go with eibach (let alone the dropping cars thing) im not much into dropping cars but i know the reputation that eibach has is... well lets just say its like K&N air filters has... high up there, so i would go with eibach. then again the other ones you can adjust the height to whatever you want. hope that helps.
Old Sep 24, 2011
MindBomber's Avatar
Live for the Twisties
Go eibach, best spring maker in the world, versus what look like ebay coilover sleeves.
Old Sep 27, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
If you drop that low on 17 inch rims you're going to need to invest in some camber kits
Old Oct 17, 2011
Midnight Run's Avatar
Midnight Run is an unknown quantity at this point
go with Eibach springs. Stay away from buying used coilovers. The absorbers probably need an over-haul and that will offset you even more $ to get 'em rebuild/re-valved.
camber kits are needed only if you lower the car by a lot. Eibach's don't lower your car that much. An accurate alignment after lowering springs are settled will do the job.
Old Mar 25, 2012
Scenemaker's Avatar
Scenemaker is an unknown quantity at this point
I disagree with only needing camber kits if you drop by xx amount. Anytime you sway from stock ride height, your camber will be off by enough to put extra wear on the insides of your tires. Tire replacement cost > camber kit cost any day.
Old Mar 25, 2012
MindBomber's Avatar
Camber can be adjusted within stock guidelines with lowering springs, it just depends how high the spring rates and how aggressive one drives.
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
EvilTwin
Nov 8, 2001 12:17 PM
2Hondaz
Nov 8, 2001 11:00 AM
Zillaaa
Nov 2, 2001 05:11 PM
