2002 Civic LX- OEM Keyless Entry Install
Old May 21, 2013
haynesaz's Avatar
haynesaz is an unknown quantity at this point
hello guys, new to the forum and hoping someone can provide me with a simple answer to my question...
i just bought a 2002 lx... car doesnt come with keyless entry from the factory but i want to install the oem system. i took apart the center console to make sure a previous owner didnt install the H & A kit, and sure enough nothing is there.
my question is, since H & A and Honda no longer sell the accessory kit to install keyless on a LX can i rob the brain box and supporting harness off of a wrecked EX or something like that?? and/or, will the EX donor civic have keyless entry installed like the Honda accessory kit for a LX or will it be different? (more built in/impossible to pull out)
i have found the modules listed at junkyards and such, however the real issue i am having is the actually wiring of the module.
Thanks in advance for the responses, i've tried searching for like an hour and cannot find a straight forward answer to this.
Old May 21, 2013
haynesaz's Avatar
Re: 2002 Civic LX- OEM Keyless Entry Install
i just realized that i am in the 6th gen forum... sorry, mods please delete
Old May 22, 2013
CraigW's Avatar
Tough call on that. Did the EX even use the same module ?? What parts are in LX kit ??(extra harness?)
They used to make an aftermarket keyless only...now it is all only alarm systems.
You could get alarm and only use keyless feature.
Old Apr 23, 2014
Thaik's Avatar
Thaik will become famous soon enoughThaik will become famous soon enough
You could try wiring it yourself, cut the connector that comes with the keyless receiver module and wire it to the existing wiring in the car.
The wiring diagram is the honda service manual. It indicates which colors goes where and what it does.
I'm actually searching for a the right keyless remote for the receiver I bought along with its connector.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
shaejb15
Apr 26, 2015 07:44 PM
darwin-t
Apr 18, 2015 09:29 PM
smmahan
Apr 15, 2015 08:17 PM
