Check engine light
Old Oct 4, 2012
Payton's Avatar
Payton is an unknown quantity at this point
Check engine light
My 96 ex is throwing a check engine light I have checked the codes and it says I have high voltage what does this mean and how do I fix it???
Old Oct 4, 2012
Re: Check engine light
How did you come up with this?
Old Oct 5, 2012
Payton's Avatar
I have a code puller like advance does
Old Oct 5, 2012
I meant your description.
Post the actual code number.
Old Oct 5, 2012
Payton's Avatar
P1298
Electrical load detector (eld)
High voltage
Also have oxygen sensor codes but I don't care about them right now
Old Oct 5, 2012
Originally Posted by Payton
P1298
You SHOULD care.
Word:
http://chowcman.com/krispycreme2010/...r%20Wiring.pdf
See if that fits your problem.
Old Oct 7, 2012
Payton's Avatar
The fuse was blowed its fixed now thanks dude
Old Oct 7, 2012
The blown fuse was only a SYMPTOM. If you didn't fix the problem (wiring or otherwise) that CAUSED the fuse to blow, you will still have the problem. Probably shortly later on, when it blows again.
HTH
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
