2000 Civic power door lock issue
Old Jun 21, 2011
swhuffman96's Avatar
swhuffman96 is an unknown quantity at this point
Angry 2000 Civic power door lock issue
Hello, this is my first post but I feel I've searched everywhere to no avail.
2000 Honda Civic door locks will not work. They will not work with keyless or manual switch. When the switch is activated, I hear a click in the keyless module under the drivers kick panel. I replaced the driver's side lock actuator but still have the same problem. Also, when I hit the lock switch or push down the lock **** (with door closed) I here the click and the dome light goes off. When I then unlock the door with the ****, the dome light comes back on. I'm assuming this is normal function but the light goes off even when the doors do NOT lock using the switch.
I've done all the power lock troubleshooting in the manual and the results mostly say bad actuator. That is why I already replaced that but it didn't work.
Thanks for any help.
roverben
Jan 21, 2019 05:16 PM
darwin-t
Apr 18, 2015 09:29 PM
Thees1
Apr 14, 2015 08:23 AM
NoToRiOuSxPiNoY
Bolt-on Engine Performance
Nov 7, 2001 11:19 PM
Ramen
Canada West
Nov 5, 2001 06:07 PM
