1998 civc hx radio harness cut
Re: 1998 civc hx radio harness cut
Junkyard or check into the Metra 71-1720 harness/plug for 86-98 Honda/Acura.
You would need to research and double check the wire colors (for the harness and the auto) the12volt.com has info, and the 6th gen factory manual is available on the web for free.
Sorry to hear about your radio =/ (Didn't know thieves were into jacking stock radios now...sheesh) Craig covered pretty much all the bases, but if you plan on replacing the radio yourself, make sure you got a pair of crimpers, and Crutchfield has some fantastic DIY's for installing radios, stock and aftermarket.
Sep 26, 2023 06:44 PM
sch2cm
Jul 21, 2015 09:58 PM
Jul 14, 2015 03:39 PM
Jul 12, 2015 11:54 AM
