Gauge Cluster - No lights when it rains
Old Jul 17, 2010
NastyNas's Avatar
NastyNas is an unknown quantity at this point
I have a 96 Civic coupe with an intermittent problem with the interior gauge cluster lights. Whenever I'm driving in the rain, the lighting around my speedometer, tach, gas gauge, etc all goes out. Once it stops raining and things dry out they begin working again, until the next time it rains. I can't find where the water is leaking in, but I'm also not really sure where to look. Does anyone have any suggestions? Thanks!
Old Jul 17, 2010
Re: Gauge Cluster - No lights when it rains
sounds like a bad ground for the cluster somewhere in the engine bay. or a loose battery cable or connector.i doubt water is actually leaking into the gauges, more likely water is getting around a loose ground in the engine bay somewhere.
Old Jul 18, 2010
lazlong's Avatar
Look for corroded connections.
Old Jul 18, 2010
Mad Dog Tannen's Avatar
It sounds to me like you have an exposed wire. Inspect the wires that go to/from your guage light and look for worn insulation or exposed copper, start under the hood and places that could get wet.
HiImBrandon
Jun 1, 2015 07:34 AM
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
