Window motor wiring
Window motor wiring
I'm working on a 1996 Honda Civic and am having problems with the power windows. Does anybody know why there are four wires going to the drivers side window motor and only two to the passenger side?? Any help would be much appreciated
Re: Window motor wiring
Here is the wiring information.
One wire is a ground, one wire is for the pulse signal from the motor during "auto down" and the other 2 are the motor leads.
I really thank you for your response!!!!!!!! I am working on an 1996 Honda Civic EX. It is a 2 dr coupe. I see the diagram that you attached is for a 4 dr. Thanks again for the info
The EX wiring is here apparently --> https://www.civicforums.com/forums/1...dow-demon.html
( I tried to reload the EX and got a message)
I edited power window demon to 96 EX info, hth.
Hey Craig, thanks so much for your help!! Its nice to know there are people out there like you that take the time to help others. I was wondering how I could view the factory manual that you mentioned. Thanks again, Rick
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
Blazz
May 25, 2015 10:56 PM
Supramk3
May 11, 2015 07:55 PM
