Doors Locking Automatically
Old Aug 4, 2009
amberlynette's Avatar
amberlynette is an unknown quantity at this point
I have a 97 Civic EX coupe. The other day my door locks decided to start locking automatically. While driving they lock and then they try to lock like five more times and then a little while later they try again, and again, and again. It gets quite annoying after a while, and I have already locked my self out of the car by accident. I haven't made any changes to my car lately so I'm not sure what caused this but if anyone has any idea how I can make it stop I would really appreciate it. Thank you
Old Aug 4, 2009
CraigW's Avatar
Re: Doors Locking Automatically
It could be the lock/unlock switch on the door (disconnect it as a test)
It may also be a problem with the switch in the drivers door that senses the position of the lock ****.
Old Aug 4, 2009
I tried holding up the lock switch and it still tries to lock. Even when the doors are already locked it tries to keep locking them. Thank you
Old Aug 4, 2009
CraigW's Avatar
Does it ever do this when just sitting with engine off & key out of ignition ??
If you are in the car when off, all doors closed and unlocked and you push down on the drivers door lock ****. Do all the doors then lock ??
Old Aug 4, 2009
It only does the locking thing when the car is on. The drivers side will only lock if the handle is pulled out a little bit and the passenger side only locks sometimes. I just got the car maybe a month ago. Both doors do that though, you have to pull out the door handle and then push the lock button.
Old Aug 4, 2009
CraigW's Avatar
"It only does the locking thing when the car is on"
That is scary... both my theories are out then.
The drivers door should be lockable when closed either by key, lock switch or pushing the lock **** down... but requires handles held if open (Honda's are made that way to help prevent lockout)
Old Aug 4, 2009
Yes my car apparently thinks it's funny to lock me in while I'm driving. I have no clue where to even begin to try to figure it out. The other thing I didn't mention is two days before it started this it started blowing the fuse for the dash lights. I love my car but it's making me crazy.
Old Aug 5, 2009
I think it may be the switch that is supposed to lock the doors only when you start the car, but I have no idea where that is. Any ideas?
Old Aug 5, 2009
CraigW's Avatar
Does your car still have the original stereo that it came with ??
(on 6th gens some items are controlled through the audio units)
Any recent mechanical or electrical work been done ??
Old Aug 5, 2009
i bet the previous owner had an aftermarket alarm that was partly uninstalled or stopped working. they have the auto door lock thing built-in and i disconnected mine by cutting a yellow wire under the dash. but i would need to know more about whats in the car. have you looked aabove the brake pedal where the fuses and stuff are? see if theres any old alarm boxes.
Old Aug 6, 2009
Craig:
No I don't have the stock stereo anymore but I've had the stereo in it for a while now. No recent work has been done to my car either.
Gearbox:
Yes there is an alarm under there but it doesn't work. I know the keychain works because it lights up but nothing happens. I was thinking about that yesterday as a possibility.
Thanks for all your help
Old Aug 6, 2009
electric130's Avatar
that's normal for civics. that's how honda designed them. it's supposed to prevent you locking your keys in the car by making you consciously lock the doors either by pulling the handle, or lock with the key from the outside.
i'm betting on the alarm unit causing the problem.
Old Aug 6, 2009
unTuned's Avatar
is there any chance you could get under there and take a picture of the old alarm box? or open it up and take a picture? it might help.
h4ldol
Jun 28, 2015 10:18 PM
h4ldol
Jun 3, 2015 03:26 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
