Running without a thermostat
Old Jun 4, 2018
Slicer1989's Avatar
Slicer1989 is an unknown quantity at this point
First all, I don't wanna hear the crap. My car has a bad head gasket and I know it, I can't afford to fix it RIGHT this minute. coolant is NOT mixing with oil, though a little oil IS Getting into the coolant.
anyway, I had the suggestion of running it without a thermostat temporarily as it will reduce temp and pressure, thus not pushing coolant out or into the overflow tank (And not letting it back in) it would probably be only a month, maybe 2 months max. I live in GA where it's summer the average temps during the day is 85+ and at night between 65-75.
I know alot of people say its terrible on an engine, but would it be okay for just a few months until I am able to get all the parts to fix it? This is my only car, My only way to work...
Old Jun 4, 2018
Re: Running without a thermostat
You can run without the stat if you wish, of course you probably already heard all the reasons to not do it that way.
And removing the stat probably won't help anything, because:
It will continue to push liquid out of the radiator into the reservoir and probably continue to overflow the reservoir, and after it's pushed almost a quart of liquid out of the radiator it will probably still overheat.
Old Jun 4, 2018
Slicer1989's Avatar
So basically nothing I Can do it at all to even limp it along? Oh well I guess.
Old Jun 4, 2018
When these blow the head gasket, at least in the early stages,
Low liquid level in the radiator is the usual reason they end up running hot and overheating.
So.....Depending on how rapidly it is pushing liquid out of the radiator......Fill the radiator up long before it gets low.
Old Jun 4, 2018
Slicer1989's Avatar
I was going over a month with daily 50+ mile trips before it did, then it got down to every 2 weeks, then once a week, now it seems like even when I top it off and bleed it, it still likes to start to run hot again.
Old Jun 4, 2018
when it starts overheating... too late, it's gonna go at any moment
while it is still only pushing coolant out of overflow, mine lasted for more than 6 months and i still drove from QC to TN. never overheated, but it was loosing coolant, so i was pouring in new coolant.
Old Jun 4, 2018
Slicer1989's Avatar
It seems to only overheat when it's low on coolant, I drained all the old cloudy coolant, cleaned the thermostat up and refilled it, idled for 45 mins with revving between 2500-3500 RPMS, temp never budged, drove it around, temp never budged.... it seems to only do it once it's pushed out enough coolant to be low... otherwise, when it's full, it runs perfectly fine.
Old Jun 4, 2018
then keep filling. check everyday
Old Jun 4, 2018
Slicer1989's Avatar
I also notice that the softer I drive (meaning keeping the rpms low, and not running it hard) the less coolant it pushes out... Eh, I guess i'll just keep a few gallons of water in my car.
tifossi
Jul 14, 2022 03:19 PM
jacobeckstein
Aug 23, 2016 10:43 PM
Macalroy38
Jan 30, 2015 01:10 PM
eswar_ner
Oct 8, 2014 06:12 PM
BartusCompater
Dec 5, 2012 06:48 PM
