Exhaust connection problem
Old Mar 30, 2018
MonoDemon's Avatar
MonoDemon is an unknown quantity at this point
I have a 98 civic ex and too make a long story short the bolts connecting my header pipes to the front cat were removed for a job but there was only one put it back on and O2 sensor kicked mpg went down drastically and it was loud due to the seal not being tight so i got some exhaust hardware today came with springs but they wouldnt fit in between the connectors so my question is it just 2 bolts that go here or am i missing something? Very begginer with anything mechanical so this might be a dumb question.
Old Mar 30, 2018
Colin42's Avatar
Re: Exhaust connection problem
Spring goes between the nut and the flange, do you have a gasket in there?
Old Mar 30, 2018
MonoDemon's Avatar
There is like a male to female adapter thats on the inside but as for gasket no im not actually sure what it would look like but i put the bolts that came with springs and it wouldnt fit the pipes wouldnt connect over the springs but now it rattles hard but drives better with just the bolts ive put on
Old Mar 30, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
i usually smear a little permatex ultra copper rtv on those joints. you can leak test them by sticking a shop vac on the exhaust tip and puffing around with a cigar (:
Old Apr 1, 2018
Sactocivic's Avatar
Sactocivic is an unknown quantity at this point
You need one of these in there:
Old Apr 1, 2018
Sactocivic's Avatar
Like this:
The springs go on the left side of the flange, allowing the joint to flex
Mikeds122
Jan 14, 2004 09:43 AM
JAG609
Jan 6, 2003 08:45 PM
VNlilMAN
South Cali
Aug 1, 2002 05:20 PM
JoeB16
Apr 12, 2002 09:25 AM
Jeff
Mar 6, 2002 03:04 PM
