Starter keeps going bad
Old Jan 6, 2016
Hatchhead's Avatar
Hatchhead is an unknown quantity at this point
So i got my starter replaced for the second time and now the second one seems to be going bad now. The shop said if the second one goes bad it might be a bad flywheel. Anybody have any ideas on what else it might be? Some times when i start the car it takes a couple of turns to crank
Old Jan 7, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Starter keeps going bad
It could be many things, It might not even be starter related...
for example if you're not getting enough fuel, ignition voltage to plugs, or, the ignition timing is off, those could lead to starting issues.
If your starter is cranking it should be fine.
Try turning the ignition to the point where the dash lights turn on, then off again. Do that three times before starting. If it starts right away after that you have a fuel pressure issue, which is common with older cars while starting.
Old Jan 7, 2016
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Parts store remanufactured starter rebuilt in a 3rd world nation with no quality control? The failure rate of factory parts is very low. The failure rate of most parts store reman electrical parts (starter/alternators) is quite high. I remember reading about 10-12 years ago that the duralast reman GM alternators had a 70-80 failure rate within 2 years. I hope that the figures were incorrect, but I won't put them in my cars. I have seen too many that failed prematurely to trust them
Old Jan 7, 2016
CraigW's Avatar
^^^^Exactly why I despise auto parts store JUNK.
Old Jan 9, 2016
Hatchhead's Avatar
Got my car back after it was at the shop for two days. They said nothing was wrong. Should i take it to another shop?
Old Jan 10, 2016
Wait til it's broken this time.
mgcivicdriver
Engine start problems
16
Dec 10, 2015 11:58 PM
98hondaciviclx
Oct 30, 2015 12:21 AM
pnamajck
Oct 27, 2015 07:09 AM
R Steele
Oct 22, 2015 05:09 AM
nooby7
Oct 17, 2015 03:10 AM
