Engine Acceleration/Deceleration Issue
Hello, I have a 1998 civic cx, D16y7,. I drove the car yesterday morning, went 32 miles, no check engine, no issues. Parked the car, then 1 hou later drove 6 miles to work, no check engine, no issues. 1/2 hour later drove car about 4 miles and check engine light comes on. The car then started to act up,
while going at a steady speed, the engine would decelerate as if the ignition was cut off, t hen 4 or 5 seconds later would cut back on. So, from that point on it would cut off and on repeatedly. I jumped the ecu and got 1 long blink on the check engine light, which did not repeat over and over like other codes. I can't find a code 100 in the OBDII list. Any Ideas? Thanks, BOZOtc
Re: Engine Acceleration/Deceleration Issue
Get the actual code number (in the standard OBD2 "Pxxxx" format), then you have something to look up.
OP... you may have meant CEL code P0100. http://www.obd-codes.com/p0100 6th Gens do not have a MAf sensor but does have a MAP sensor on the throttle body. Map sensor testing: http://troubleshootmyvehicle.com/hon...e-map-sensor-1
^Blink code format doesn't correspond to any OBD2 codes.
OP needs the real OBD2 code read.
I got the code and replaced the IACV with new. I had replaced the IACV purchased on Ebay,who knew you could buy new parts that did not work..
Thanks for the help.....................
Extractfromtab
Sep 10, 2020 04:21 PM
montanacivic
Aug 29, 2015 03:21 PM
Kenjitsu
Aug 28, 2015 04:45 PM
