#44 fuse keeps blowing! Help me.
Old Feb 19, 2015
Kenji's Avatar
Kenji is an unknown quantity at this point
Blown #6 fuse after jump start
Car: 2000 Civic EX Auto STOCK
Recently was jumped. After the jump the car would turn over, NOT start but would blow the FI fuse, each time it is replaced. Please advise!!
Old Feb 19, 2015
Re: Blown #6 fuse after jump start
Might not be related to jump start, may be a new problem.
Wiring diagrams could tell what all is connected to the fuse, then you can start isolating areas or components.
Old Feb 21, 2015
Kenji's Avatar
Could someone help me on where to start?
Old Feb 21, 2015
What are you seeing as fuse #6?
How many amps?
Which fusebox?
The only #6 fuse I see in my diagram is in the dash fusebox and is for the optional security system.
Old Feb 23, 2015
Kenji's Avatar
Recently was jumped. After the jump the car would turn over, NOT start but would blow the FI fuse #44(under the hood), each time it is replaced. Please advise!!
Old Feb 23, 2015
Re: #44 fuse keeps blowing! Help me.
Items that share fuse 44:
4 fuel injectors
IAC valve
Main relay
PCM
Disconnect each item and see if the fuse no longer blows?
Then reconnect one by one and see which causes the fuse to blow?
Harding12390
Apr 6, 2018 11:43 AM
JAMorganIII
23
Jul 4, 2015 11:52 AM
g4384063
May 30, 2015 11:21 AM
Ma213802
May 18, 2015 07:01 AM
Dakker
Jan 21, 2002 12:55 PM
