Need advice
Old May 26, 2014
rnbautobody's Avatar
rnbautobody is an unknown quantity at this point
Need advice
Have a 2000 civic with a 1.6 vtec. Motor will crank...no fire. Made sure coil and distributor were good and still no fire. Am thinking crank position sensor next. Am lost and need help. Been reading threads and believe this may be the issue.
Car was running and just shut off. Will crank but not fire. ANYBODY?
Old May 27, 2014
Re: Need advice
Got compression?
Got spark?
Got fuel?
Did it jump time?
Old May 27, 2014
Re: Need advice
have compression, no fire, dont think it jumped time but did not check. was wondering if it could be the cps.
Old May 27, 2014
Re: Need advice
and has half a tank of fuel.
Old May 27, 2014
Re: Need advice
no fire
You mean no spark?
How did you test the coil and distributor?
Is the coil any good? That's usually the first thing to quit.
Easy test, pull cap and rotor off to expose the coil, crank the engine. Got spark? (I assume no)
Then connect a dwellmeter to the primary negative side of the coil and crank it. Got a dwell reading?
If there is dwell but no spark, the coil is bad.
If there is no dwell, then keep troubleshooting.
The sensor in the front of the crank is used for misfire detection (CKF). I'm pretty sure it will run without it.
The CKP is in the distributor.
Tyler93
Mar 20, 2016 09:03 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
PunX
Sep 23, 2015 10:45 PM
sf3r8z
Sep 23, 2015 03:26 PM
bhollie
Sep 22, 2015 11:08 PM
