35L (9.24gal) Fuel Tank??
Old Apr 27, 2014
What_It_Do's Avatar
What_It_Do will become famous soon enough
So, I found out my car runs out of fuel when the gas needle is 1/8th above "E" on the gauge.
It then takes 35L (9.24gal) to fill up.
What the hell!
I need to stop frequently, since according to manual it should be 45L!
What gives?
Old Apr 27, 2014
Re: 35L (9.24gal) Fuel Tank??
Do you know for a fact that the tank was physically empty and the pump has no issues at all, or is 1/8th tank just where it quit running at? Was the car on flat level ground at that time, not going around a corner or tilted to one side?
Is the bottom of the tank caved in, or has it been damaged from dragging or road debris?
Old Apr 27, 2014
What_It_Do's Avatar
I don't know if the fuel tank was physically empty.
No damage.
It's ran out of gas a few times at the same spot on the gauge, I'll start it back up, continue maybe 1/2mile and it would die again, the distances between stalling out get shorter.
So for the past year, I've just been making sure to not drive it below that 1/8th point above Empty.
Generally I would say the angle doesn't matter when the vehicle stalls out. The gas gauge does drop temporarily as I drive around on/off ramps, be restores proper reading shortly after.
Old Apr 27, 2014
The gauge must be LYING to you! Slap it!
Sounds like it was empty enough for the pump to quit pumping liquid.
I guess you have to decide if you want to pursue fixing it ($$$) or if you just want to get gas sooner than 1/8 tank.
Does your low fuel light work (assuming it has one)?
When the tank is below 1/2 full, gauge dip on long turns or acceleration is usually normal due to the location of the sending unit in the middle of the tank. There's a service info stating such for 96-00 Civic.
Same for if you turn hard enough for fuel slosh to uncover the pump, the engine will stumble when the pump sucks air.
Old Apr 28, 2014
remove the tank and give it a thoroughly cleaning. possibly tons of gunk inside...
cwisenbaker06
Aug 19, 2015 04:29 PM
Hrddrvs
18
Aug 17, 2015 01:08 PM
andyandyy
Aug 7, 2015 07:14 AM
shaejb15
Jul 27, 2015 03:48 PM
jody501
Jul 10, 2015 11:01 AM
