Cannot find seal for engine
Old Apr 14, 2014
hoader's Avatar
hoader is an unknown quantity at this point
I have a 98 honda civic lx but does not have the original engine. Number on the engine is D16Y7 and 2623059. Can these numbers give additional info about the engine? The rear main seal gasket set did not fit the flange from the engine. The seal I got for that vehicle from the auto store slid in with my fingers and the flange is to wide for the paper gaskets. They had no other options or info when I returned the set. Maybe the engine in there did not come out of a civic.
Thanks Hoader
Old Apr 14, 2014
Re: Cannot find seal for engine
98 LX? You have the right engine according to Wiki. Might be from a different year or something?
Try a dealer seals or a different parts store/brand?
D16Y7
  • Found in:
    • 1996–2000 Honda Civic DX/VP/LX/CX
    • 1998–2000 Honda Civic Special Edition – SE/EX (Canada)
    • 1996–1997 Honda Del Sol S
    • 1996–1997 Honda Civic Coupé LSI
      • Bore and Stroke: see D16 Series Engines
      • Displacement: see D16 Series Engines
      • Compression: 9.4:1
      • Power: 106 hp (79.0 kW, 107 ps) at 6,200 rpm
      • Torque: 103 lb·ft (140 N.m) at 4,600 rpm
      • Redline: 6,800 rpm
      • Rev-limiter: 7,200 rpm
      • Valvetrain: SOHC (4 valves per cylinder)
      • Fuel Control: OBD2-a MPFI
      • Head Code: P2A-2
      • Piston Code: P2E
      • ECU Code: P2E
      • Cam Gear: 38 Tooth
Old Apr 14, 2014
I plugged in 98 civic and got this part number
91214-PLE-003 OIL SEAL (80X100X10) (NOK)
$18.50 list, or $12.95 plus shipping from Majestic.
http://www.hondaautomotiveparts.com/...VIN+Number+---
I went from 1985 up to 2005, all seem to use the same part number in my catalog.
I think your parts store parts is wrong.
Old Apr 14, 2014
My info says it uses RTV sealer (like Hondabond), not a paper gasket.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
leon1
Apr 28, 2015 07:32 PM
jstotts
Apr 20, 2015 09:32 PM
bahena08
Apr 11, 2015 05:09 PM
Grey
16
Jan 27, 2002 11:34 PM
