1999 civic eld
1999 civic eld
I have a 1999 civic and the lights on the dash as well as headlights flicker. Alternator and battery test good. Is there a way to replace the ELD? Electric Load Distributor.
Re: 1999 civic eld
It's a load DETECTOR, and what is the problem?
Have you monitored voltage at the battery while this is happening? What are the readings (high and low)?
Re: 1999 civic eld
I have taken it to autozone and had the battery and alternator tested and both tested good. However the headlights and dashlights weren't flickering at the time. The problem is sometimes the headlights and dash lights flicker. Also the SRS light comes on.
Re: 1999 civic eld
Have you checked for codes in the SRS computer?
Have you checked for codes in the engine computer?
Have you done the test I suggested in my last reply?
Re: 1999 civic eld
GO back to Autozone for checking for engine codes.
If there is no code related to the ELD, it's probably ok.
Search here for how to retrieve and read SRS codes.
Connect a volt meter. Drive around. Note normal voltage when everything is working right.
When you see the lights go dim, read the meter to see what the voltage is.
I want to know both.
Reason: What you see COULD be normal as the computer turns the alternator on and off. I just want to determine if what you see is abnormal.
Or how to check hi and low voltage? Sorry but I'm new to this.
usajags84
15
Aug 19, 2015 03:12 AM
tattedlariat
Apr 20, 2015 09:26 PM
aultman1990
Apr 19, 2015 07:14 AM
WeRkX
Nov 1, 2001 10:33 PM
