Clutch Failing?
Old Jul 24, 2013
fjd_98's Avatar
fjd_98 is an unknown quantity at this point
Clutch Failing?
I think the clutch is going on my '98 Civic. It is becoming increasingly difficult to get it into reverse and 1st gear. It takes a lot of grinding before it slips into gear.
Could this be anything other than the clutch failing?
How much should I expect to spend on a new clutch?
Is there anything else that could solve this?
Old Jul 24, 2013
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: Clutch Failing?
That sounds more like your synchros (transmission) are bad. If it were slipping or all gears were hard to get into, then I would say it was your clutch. Try rev matching when downshifting so your synchros dont have to do as much work.
Old Jul 24, 2013
GolNat's Avatar
Prelude Owner
Re: Clutch Failing?
Also before shifting into reverse try shifting into 2nd first then reverse. My 88 accord would grind going into reverse if I first didn't shift into 1st gear (synchro was going bad). Since your 1st is grinding 2nd might work better.
Old Jul 25, 2013
got2run5's Avatar
Re: Clutch Failing?
You could also flush your tranny. Most people seem to go with Honda manual transmission fluid but I've only heard good things about redline mtl from people that didn't go Honda. It probably won't fix the problems but it might make them a little less noticeable.
Old Jul 31, 2013
fjd_98's Avatar
Re: Clutch Failing?
Took it to the shop down the street. They replaced the master cylinder and added fluid for $235. Is that a reasonable price?
Old Jul 31, 2013
GolNat's Avatar
Prelude Owner
Re: Clutch Failing?
Did it fix the problem?
Old Aug 3, 2013
fjd_98's Avatar
Re: Clutch Failing?
Yes, it shifts great now. I hope it lasts.
Sep 27, 2015 11:33 AM
Klame9420
Sep 7, 2015 10:03 PM
tommycanada
Sep 5, 2015 04:59 PM
Stock 99
Sep 5, 2015 06:06 AM
dantheman42
Sep 4, 2015 01:10 PM
