Miss fire 96 civic
Old Feb 28, 2013
Clubby88's Avatar
Clubby88 is an unknown quantity at this point
Miss fire 96 civic
Hello all changed the plugs and leads in my civic 96 D16y5 replaced plugs with iridium plugs and now when I'm in low revs it jumps and misfires but when in try to accelerate harder it stop missing and it also misses when I'm idling please help
Old Feb 28, 2013
go-part's Avatar
Former Sponsor
go-part is an unknown quantity at this point
Re: Miss fire 96 civic
It sounds like your TPS is acting buggy.
http://www.buzzle.com/articles/sympt...on-sensor.html
Old Mar 1, 2013
Clubby88's Avatar
Sounds about right can I replace it ?
Old Mar 1, 2013
iim1rmg's Avatar
iim1rmg is an unknown quantity at this point
If it was running well, you changed the plugs, and now it is misfiring-
First thing- double check and make sure you installed the correct plugs.
If they are the correct plugs for the application, make sure they are NGK or Denso. Some Hondas have been known to be very picky about what plugs they are happy with.
Not saying other brands never work, but other brands have been known to be rejected by their Honda :-)
Old Mar 1, 2013
Clubby88's Avatar
I used Bosch plugs the local store looked in there book and told me these were the top of the range plugs they had for my car.
Old Mar 2, 2013
Bubbamosher's Avatar
Bubbamosher is an unknown quantity at this point
Check the gaps in the plugs also, even though most of the upper range plugs come pre-gapped, a small jolt while they are still in the box or during installation could throw it off. Just speaking from experience I have had with my truck.
Old Mar 2, 2013
Did you ever manage to check the cam timing or ignition timing?
Why in the he!! didn't you mention this in your other thread?
Top range means "highest profit margin".
Throw those away and buy the correct NGK plugs.
Not kidding one bit.
Botch plugs are the first things to go when looking for driveability problems.
This handy tool here will install Botch plugs directly into the dumpster from 20 paces with amazing accuracy:
Not kidding one bit about this either. I keep it in one of the toolboxes at work.
CarStuff
Dec 6, 2020 12:52 PM
usajags84
May 10, 2015 08:11 AM
cooldan1
Apr 23, 2015 10:49 AM
Blaster30
Apr 22, 2015 12:21 PM
usajags84
Apr 10, 2015 09:54 PM
