Battery light/ Power loss... Please help!!!
Old Feb 14, 2013
Tylerleefalter's Avatar
Tylerleefalter is an unknown quantity at this point
I'm actually having problems with my '99 Civic LX... My battery light starts flickering as well as my lights interior and exterior at or above 3000rpm I just replaced the battery. Thinking it may be the alternator, but when i start the car and remove the positive battery terminal it stays running (was told if alternator is bad, car would die after removed) and I've also gotten the alternator tested and they said its fine... I'm lost... Anyways Thanks a lot for your time!!!
Tyler
Old Feb 15, 2013
Re: Battery light/ Power loss... Please help!!!
The alternator controls that light.
Charging voltage is fluctuating
at or above 3000rpm
This fact is important.
Why? Was it bad?
Good thinking.
Don't do that again. The battery acts as a HUGE capacitor to absorb voltage spikes, and you removed it from the circuit. You can fry all sorts of electronics doing that.
Back before the days of electronics and microprocessor controls, this was less of an issue.
The test is all but worthless, it would only tell you if the alternator is completely dead.
It cannot tell you if the alternator is weak.
The engine will continue run on about 10 amps of current.
That means the alternator could be smoked and limited to 10 amps, and the engine could still run on it.
How was it tested?
Did you carry it in to the Zoo and have them put it on that machine?
Or was it tested live, on the running car, tested at 3000+ RPM, WHILE the problem is happening??
(Even at that, the test only tells if the alternator is charging or not. You still have to figure out why.)
Wiring good and not shorted on the brackets under the intake manifold?
I don't have the answer. You need improved testing to figure out whether it is the alternator or something else, maybe in the wiring.
Old Feb 21, 2013
Well I appreciate the reply, I went I believe the next morning and got it retested at a honda dealer... It was the alternator's voltage regulator was actually causing it to overcharge and essentially fry my battery so I replaced it (definately not there) XD. God those prices almost gave me a stroke lol...
Again thanks for the insight! now I'm off to find some new projects for the engine itself lol!!!
Old Feb 21, 2013
Definitely not like DangerZone prices, and certainly not DangerZone quality.
I've been burned too many times by the Zoo. I can't trust them for much.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Cyborg Ninja
20
Jul 11, 2022 03:44 PM
Black91civic
Jun 6, 2015 08:15 AM
HiImBrandon
Jun 1, 2015 07:34 AM
SSMatey
Apr 13, 2015 06:09 PM
