Timming belt tensioner noise
Hi i am the owner of a 1996 Honda Civic LX. I have noise which sounds like its coming from up under my timing belt cover. The guy i bought it from said it was a faulty Tensioner bearing and is not a immediate threat. My question is: Will that (faulty bearing) cause my check engine light to come on? I had a New O2 sensor installed as well as the timing set to 12 degrees because of smog fault codes..p1362, p1361, p0135. I suppose the mechanic cleared the memory. So the check engine light is back on.
Thanks in Advance!
Thanks in Advance!
Re: Timming belt tensioner noise
That's the one that goes bad all the time.
Take the belt off and spin that pulley.
Bet it feels rough and spins loud.
Start it up without the belt and noise is gone.
You don't know?
So then......What codes are in it now?
Clear the codes, see what comes back first.
p1362, p1361,
p0135
[quote=ezone;4631558]I bet he meant the AC belt tensioner pulley.
Nope.
You SUPPOSE?
You don't know?
TDC sensor codes. Distributor? ECM? Wiring?
Bet it wasn't factory. What brand was it?[/q
Im not sure about the o2 sensor.....it was in a blue box is all i know. The obdII scanner read p1361 , p1362, and after installing the o2 sensor it no longer gave the p1365 code.
After installing the o2 sensor the check engine light came back on omitting the P1365 code error. ....The mechanic installed new distributor components stating it was no electrical charge on 3 and 7 inside the distributor and no fault codes were displayed..its been two days and the engine light is now operating as it should. Yesterday i took it to get smoged and it passed with flying colors...well below max.....HC(PPM)29/14---co(%)0.39/0.45---NO(PPM)329/384.
Nope.
You SUPPOSE?
You don't know?
Thanks people....Hondaz Ruke.
After installing the o2 sensor the check engine light came back on omitting the P1365 code error. ....Because of the codes The mechanic installed new distributor components stating it was no electrical charge on 3 and 7 inside the distributor and no fault codes were displayed..its been two days and the engine light is now operating as it should. Yesterday i took it to get smoged and it passed with flying colors...well below max.....HC(PPM)29/14---co(%)0.39/0.45---NO(PPM)329/384.
159
Jul 5, 2015 09:54 PM
Tim1959
Jun 3, 2015 08:15 PM
Bradel26
May 30, 2015 10:24 AM
