30 psi Compression after 1.5 months long transmission work
Old Feb 10, 2013
marshallinux's Avatar
marshallinux is an unknown quantity at this point
After working on and off on the transmission for 1.5 months, I finally got the tranny installed and put everything back together to find out that the engine won't start (the starter does crank the engine).
Compression tests show 30, 30, 28, 68 psi. Before the tranny work, I had ~130 on all cylinders. Is it stuck open valves? If so, how can I fix them? One of the reasons why I think it may be the valves rather than the rings is in this rainy wet NW, my detached garage gets a lot of moisture and things tend to rust. The car didn't run for 1.5 months. So... Thank you!
mattdoc
Mar 14, 2017 12:10 PM
Flipg123
May 8, 2015 01:15 PM
ORskier
May 3, 2015 12:54 PM
jackoncruzpr
Apr 16, 2015 12:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
