Where to start?
Old Oct 8, 2012
arizaga8799's Avatar
arizaga8799 will become famous soon enough
Exclamation Where to start?
auto zone just hooked up my civic and gave me a p1259 code which is vtec system malfunction giving 1: vtec open or short circuit condition 2: vtec solenoid valve fault 3: vtec pressure switch fault 4: blocked oil passage. I'm new to the civic world more less vtecs are these easy fixes? I have also been having overheating problems since I bought the car and replaced ect sensor, thermostat, checked for bubbles and fan switch! could this code also be the cause of my overheating?
Old Oct 8, 2012
Re: Where to start?
Make sure the oil is full.
Old Oct 9, 2012
Re: Where to start?
then clean the screen filter, then replace the solenoid as a last resort.
Old Oct 9, 2012
Re: Where to start?
I cleaned the screen today it was clean as a whistle but do you clean at the the block too? what about the switch? they both look like they never even changed?
Old Oct 9, 2012
Re: Where to start?
there is a pressure sensor on the bottom and solenoid button on the top you can take apart, but the only screen filter is for the whole assembly. i doubt you would get it any cleaner by taking all the pieces apart but i could be wrong. you may need to just replace it and move on. dont forget to oil up the new one before installing.
Old Oct 11, 2012
Re: Where to start?
what could happen by driving it with that code on? I need a car until my next paycheck.
Old Oct 11, 2012
Re: Where to start?
i drove for a few weeks, its just annoying because the car doesnt drive or shift properly. i had a code reader in the car and would keep turning the engine light off when it came on. if you stay under 2800rpm (i know its hard for a civic) the light should stay off.
Old Oct 12, 2012
Re: Where to start?
so no harm can really be done? this morning I took off for work and it was on like usual but then I went to oriellys for work and it was off and hasn't been on since. would the screen cleaning just kicked the light off after a couple days? or is there still another issue to tackle?
Old Oct 13, 2012
Re: Where to start?
You didn't manually clear the code, so:
"It takes 3 consecutive trip cycles in which the diagnostic runs and passes for the computer to turn the check engine light off."
Sounds like your problem is intermittent, or hasn't acted up in a while. Yet.
Time will tell.
Old Oct 13, 2012
Re: Where to start?
when i cleaned mine, it lasted a few weeks and the code came back again. replaced the whole piece and the light hasnt been back in years.
Old Oct 22, 2012
Thumbs up Re: Where to start?
just an update It has been lil over a week and still no chk engine light thanks to help of all you on civicforums!
Wild Cranker
427
Jan 28, 2016 06:49 PM
SSMatey
Apr 13, 2015 06:09 PM
Trey
Jan 6, 2002 02:30 AM
black2k1vtec
Dec 6, 2001 09:49 PM
supercivic01
South
Nov 30, 2001 11:27 AM
