Help in stuck in Yellowknife!
Old Oct 4, 2012
Shaneramsden's Avatar
Shaneramsden is an unknown quantity at this point
I just replaced the ignition switch and the car was starting fine so I removed the battery terminals and went to work on my fan motor, now when I go to start my car the lights are really dim and won't start, but if I jump my car it starts fine, but if I go to start my car regularly it clicks and looses all power? I checked my battery it is reading 13 volts and I checked my alt it's. Reading like 17 any ideas guys?
Old Oct 4, 2012
Re: Help in stuck in Yellowknife!
Bad connections.
Between the battery posts and cable ends, or between cable ends and wires.
Or a bad/dead battery.
Check voltage with a load on it, not open/unloaded as before.
You have a voltmeter, learn how to use it. The answer is in front of you.
Move the test leads around, measure for voltage drops.
Old Oct 4, 2012
Okay I just re did my battery connections and they are good when I attach jumper cabled to my battery terminals on my battery and start the car it works, is my battery garbage? It was working fine just before I started working on my car ?
Old Oct 4, 2012
It will start with jumper cables attached to (I assume) the battery cables.
If battery connections are perfect, then it has to be a battery problem.
Either it is bad or just dead.
Charge and retest.
Stick your battery in a good car. Will it start it?
Old Oct 4, 2012
I only have my civic and a f450 so can't swap the battery over, any chance it could be the ignition switch/module that I swapped out earlyer today?
Old Oct 4, 2012
No. Not if it jump starts fine.
The jumper cables are taking place of a bad/weak/missing battery.
Charge and retest.
Replace if necessary.
Measure battery voltage while trying to operate the starter.
Or take the battery out and get it tested with a real load tester.
Ummmmm you may want to check your meter too.
You shouldn't have 17V when the car is running.
14.6V is about the upper limit for the charging system.
Old Dec 11, 2017
TazG's Avatar
TazG has a little shameless behaviour in the past
hey mate are you still stuck? i live here i can help you out
Old Dec 11, 2017
Colin42's Avatar
dude thread is from 2012
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
danace99
Oct 17, 2015 02:51 PM
Crazygrlinak
Oct 8, 2015 05:06 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
nixyfior
Sep 14, 2015 08:32 PM
