97 Hatchback - open hatch with no key
Old Jul 1, 2012
Jdoe's Avatar
Jdoe is an unknown quantity at this point
Long story short...I needed a car asap, so I bought this 97 Civic Hatchback CX from a guy that is now on vacation. Most of it is great, but there is one problem for now that I could use a little help with. I cannot open the hatch. The hatch is a different color from the rest of the car, so I'm guessing it was replaced, and my key does not work in that lock.
The release beside the driver's seat doesn't do anything. I put the key in the lock and it does not move at all. I try to pull it up by the handle, but nothing happens. It will not budge.
Is there any way to jimmy this open, from the inside, or outside, without doing any damage to it?
Old Jul 1, 2012
Re: 97 Hatchback - open hatch with no key
You would need to climb back there, access and remove the cover from the latch, then work the mechanism that the cable would attach to. That should get it open.
See where the cable is at, figure out why it isn't connected or working.
Then take it apart, remove the lock cylinder, take it to a lock shop...see if they can make it work with your key.
Old Jul 1, 2012
Jdoe's Avatar
Thanks, that did the trick. I didn't realize how easy this was. Trim panel popped off and I got to everything right there. Thanks.
bluedoggy1
Jun 20, 2015 11:25 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
hondadude
23
Jun 11, 2002 06:22 PM
tsunamisplash
Canada West
Jan 6, 2002 09:22 AM
Juancho007
Dec 16, 2001 01:02 PM
