Idle Issues
Old May 28, 2012
hazer92's Avatar
hazer92 is an unknown quantity at this point
Idle Issues
Okay so a few weeks ago my 97 civic ex started dying when at an idle. When first started, the idle was fine until I drove for a bit, sometimes the idle would remain at a low 500 rpm, other times, the idle would just keep dropping until the car stalled. After doing some research, I thought it may be the IACV, so I got some carb cleaner, took off the iacv, cleaned it like the guy at Oreillys said to, let it dry out and put it back on. Now my car will start but immediately the rpms dive and my car stalls. Should I just get a new iacv or is something else wrong?
Old May 29, 2012
michael3n's Avatar
michael3n is an unknown quantity at this point
Re: Idle Issues
A good first test would be to open the hood up, pull off the fuse box cover under the hood, and remove the back-up fuse for ten seconds. (you will lose your radio stations). Put the fuse back in then, and start the car. If it doesn't die like it has been recently, leave it alone to idle for ten minutes (no load: lights, radio, air, etc turned off. DON'T rev it.).
The Big Dutch
Jun 9, 2015 07:49 PM
Bradel26
May 30, 2015 10:24 AM
Allecr3
May 22, 2015 01:24 PM
crowtoo
May 11, 2015 06:50 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
