Power window and fan question..
Old Feb 19, 2012
Cbird's Avatar
Cbird is an unknown quantity at this point
Hi,
Two questions.
-power window control panel (driver control) runs all windows except front passenger window (passenger control works to run window). Is this a contact issue, or should I replace switch??
-fan control only works on speeds 3 and 4? Also, fan assembly sounds like it has a bad bearing (took it out and didn't see dirt or issues with assembly. If I need to replace, just look for cheap, or is this like the hood release cable where factory is better??
Thanks in advance.
Old Feb 19, 2012
Re: Power window and fan question..
Probably the master window switch in the drivers door.
Probably the blower resistor set burned the #2 coil open.
Could need a fan motor.
Old Feb 19, 2012
Cbird's Avatar
So, are they both a replace or can they be repaired potentially and any tips if so?
Old Feb 19, 2012
No mending, just replace.
Old Feb 19, 2012
Cbird's Avatar
Thanks, and where is the resistor set located??
Old Feb 19, 2012
Generally, the resistor is in the fan housing very close to the fan blades, and could be attached either on the bottom or the side of the housing.
You don't see the working part of it, you only see the mount and the wires.
Usually on the bottom, and has 4 wires attached.
2 screws.
Old Feb 19, 2012
Cbird's Avatar
Thanks again!!!!!!!!!!!!!!!!!!!!!!!!!!
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
beveragemp
May 25, 2015 07:11 PM
got2kids
May 9, 2015 06:45 PM
