1998 Civic o2 sensor problems!!!
Old Jan 14, 2012
dcapps's Avatar
dcapps is an unknown quantity at this point
I have a 1998 Civic EX and I had codes coming up for both o2 sensors to be replaced (can't remember what the code #'s were). I replaced the o2 sensors and took fuse out to reset. Engine light came on soon after again o2 codes. I have no fuses blowing. I have been reading about a possible short in wires but wouldn't that cause a fuse to blow? Plus I am getting horrible gas mileage (23-25 city). Should I replace the wiring harness? Stuck and need help.
Old Jan 14, 2012
lazlong's Avatar
Re: 1998 Civic o2 sensor problems!!!
First, you need to diagnose for the specific codes before just throwing parts at it. Look up the specific codes again. Then download the service manual and diagnose for those specific codes.
Old Jan 14, 2012
dcapps's Avatar
I did have the codes checked before I threw parts on it. It was codes for both o2 sensors, upflow and downflow, so that is what I replaced. I just couldn't remember what the exact codes were to post them here. Was needing to know why they were coding again.
Old Jan 14, 2012
lazlong's Avatar
Because you didn't solve the problem just by replacing parts or it's mis-firing bad enough to kill the sensors and cat again.
There's several different codes for the O2 sensors: heater circuit problem, sensor circuit problem, sensor below or above threshold, etc.
6th gen service manual: http://www.megaupload.com/?d=F1F25EH3 Download it and diagnose for your specific codes.
Please post up solutions.
Old Jan 14, 2012
dcapps's Avatar
I will call my brother and get codes and see what they are in the manual. I will post what I find tomorrow. Thank you for the info.
159
Jul 5, 2015 09:54 PM
MamaBear2015
Jun 11, 2015 07:33 PM
juror
Jun 9, 2015 02:15 PM
Blazz
May 25, 2015 10:56 PM
cruisers10
May 12, 2015 10:46 PM
