What's the chirping/squeaking sound?
Old Jan 10, 2011
stevedrum4578's Avatar
stevedrum4578 is an unknown quantity at this point
At 40mph and above there's a squeak from the engine area. It does alter with a/c on or off, or as speed goes up or down, or during turns. i might be able to rule out belts, but not sure. i've read about a chirp being cured by a valve adjustment. ideas???
Old Jan 10, 2011
MindBomber's Avatar
Live for the Twisties
Re: What's the chirping/squeaking sound?
Valves are more of a clatter than a squeak, it sounds like you need new belts.
If the sound changes when you turn on the ac it's the ac belt, when you turn it's the ps belt, if it changes based on speed then it's the timing belt/tensioner. You can spray belt dressing on the belts one at a time to see which one needs to be changed, but it sounds like they're all gone. It should be around a $500 fix and it should be addressed asap.
Old Jan 11, 2011
BlueEM2's Avatar
Whachya lookin at?
Possibly a belt tensioner going ... and the only one our cars has is a Timing belt tensioner. Check your belts. Now you say it goes up and down with speed, is it speed or RPMs though?
^Missed the tensioner part in Bombers post! FTL!
Old Jan 13, 2011
Sorry, I meant to say doesn't change. It's random, but only at 35-40mph and higher.
Old Jan 13, 2011
belts are cheap
Old Jan 14, 2011
BlueEM2's Avatar
Whachya lookin at?
LOL!! good place to start anyway
Old Jan 14, 2011
MindBomber's Avatar
It may sound random, but based on your original post it's almost definitely belts.
Get it checked out soon, if one snaps your engine is toast.
Old Jan 15, 2012
RealBoo's Avatar
RealBoo is an unknown quantity at this point
That must have been the remains of your conscious dying an agonizing death. Hope you both enjoyed Henry Rollins. Happy V-Day.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
