Crank shaft sensor on an HX?
Old Dec 26, 2011
B16TypeRGirl's Avatar
B16TypeRGirl is an unknown quantity at this point
Unhappy Crank shaft sensor on an HX?
I've got a 99 HX. I wa driving down the road and the car just cut off. I thouht it was the distributor, so I changed it. No fire to the engine. Thought it was bad, went and got ANOTHER one, still no fire. I check the voltage to the distributor and its getting power, so its got to be my crank shaft sensor. My ECU is throwing 3 different codes. 80, 7, and 3. One is a TPS sensor, one is a map sensor, and the other is some kind of emission BS. Anyway, how to I change a crankshaft sensor in a 99 HX?
Old Dec 26, 2011
MindBomber's Avatar
Live for the Twisties
Re: Crank shaft sensor on an HX?
Here's a DIY for changing the timing belt on your engine, the CKF sensor is behind the timing belt cover and therefore you will need to follow the majority of the steps up to 13 to gain access to it.
https://www.civicforums.com/forums/2...t-96-00-a.html
Old Dec 26, 2011
MelJ's Avatar
Trance Addict
Are you 100% certain? Anything from 96 and up is OBDII. Have you hooked a scanner up to pull any other codes from the car?
Old Dec 26, 2011
The only thing the scanner shows is a code 80 which is the emissions thing. I'm assuming its a crank shaft sensor because what else could possibly make it just stop? I thought it was out of gear, but I put it in first after it stopped, and it wouldn't rev or anything. It's like the engine died. It was running just fine and then it just stopped. All my lights and everything still come on. It turns over when I turn the key, but it just has no fire. Plugs n wires are all brand new
Old Dec 26, 2011
Can you pull the harmonic balancer off to get to it?
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
heath3000
Jun 27, 2015 10:30 PM
Blaster30
Apr 22, 2015 12:21 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
pichon
17
Mar 19, 2002 12:04 PM
