Timming adjustments
Old Mar 14, 2002
pichon's Avatar
pichon is an unknown quantity at this point
Timming adjustments
I have a DX model and i've been slowly trying to get it to up to SPEED with as little investment as possible. so far i've: put in a homemade SRI, lowered the car with HR springs, i changed the tire from the stock 70 to a smaller 60, the injector filters are gone, i shortened the throttle cable, and removed the coolant lines to the throttle body.
all in all i've gotten some performance improvement but i want more. which brings me to my question, Has anyone ventured into moving the crank sensor inorder to advane the car's timming? if anyone has i need to know if the crank sensor is fixed to the block or if it is adjustable(which i seriously doubt).
Thanks in advance!!
PS. by the way it is the first time i post, i looked through most of the threads and the FAQ and i tried the search before asking. so if the answer is out there and i didn't see, it let it slide, please![IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Mar 14, 2002
SuziQ's Avatar
SuziQ is an unknown quantity at this point
hey noob! tell me about this crank sensor mod. i never heard of it.
Old Mar 14, 2002
AFlyer's Avatar
AFlyer is an unknown quantity at this point
sounds like he means the timing cam gear maybe? if so, you'd be best off getting an adjustable cam gear from DC Sports or AEM. there's not a cheap way you're gonna be able to change your timing.
Old Mar 14, 2002
avenger's Avatar
avenger is an unknown quantity at this point
he's talking about ignition timing not valve timing...
i dont know where the pickup on this new engine is located, perhaps a honda tech will pass by these boards.
Old Mar 14, 2002
pichon's Avatar
yeah i'm talking about the ignition timming. see the thing is that our crank and cam sensor setup is similar to that of the Mitsubishi Tecnica (a distributorless ignition system), except that we have HONDA complexity to deal with. anyway in those cars you can move the crank sensor by removing the base where the pick up is located(it has two bolts). you then have to create a groove (usually with a drill) to allow the pick and the base to move from side to side hence adjusting the ignition timming. and let me tell you my friends, the performance improvement is significant. .Significant power increase with almost zero investment...how often does that happen?!!!
i've performed the procedure on Tecnicas but never tried it on Honda. i've looked at our engine and as far as i can tell the pick up is located right behind the damper where a plug's wiring harness can be seen.
anyway before trying it, and i will try it,[IMG]i/expressions/face-icon-small-cool.gif[/IMG] i just wanted to know if anyone had done it before so i could maybe get a heads up on what i'me going to find when i get down there.
Old Mar 14, 2002
thx1138's Avatar
thx1138 is an unknown quantity at this point
Ehhhmmm Advanced engine mod stuff here. I'm lost. But it sounds interesting anyway.
Old Mar 14, 2002
avenger's Avatar
ahahaha like there is a "significant" power increase from advancing the timing
this is more work than its worth, just leave it or see if any ignition system replacements offer variable ignition timing
edit: more detail --> sure, you'll gain maybe a horse or two, but its not worth it for the work.
Old Mar 14, 2002
mwwhonda's Avatar
mwwhonda is an unknown quantity at this point
advancing your timing CAN create significant HP increases....
Old Mar 14, 2002
Voiceofid's Avatar
End Bringer
won't advance the timing of the spark create knocks?[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 15, 2002
pichon's Avatar
advancing the timming will most definately cause knocking if you don't use a high enough octane rating. in other words stick to premium gas.
Old Mar 15, 2002
avenger's Avatar
advancing the TIMING (T-I-M-I-N-G)
Old Mar 18, 2002
pichon's Avatar
WOW Avenger!!! you are one sharp fella!!
You seem to very good at spelling. NOW... if you only knew about cars. from the things you P-O-S-T, you DON'T! I wonder if you've ever changed oil, you know O-I-L, that brown stuff that you pour into your engine. You do know where the engine is...right? [IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 18, 2002
avenger's Avatar
hey there tough guy... if your n00b *** searched my posts instead of looking at animal **** all day you'd see i know what I'm talking about. In a strung out uber-efficient D17 engine the power advancements associated with advancing your ignition timing are not worth going into the block and moving the sensor. The HP gains are not going to be amazing, and the improved throttle response you get from advancing your timing is not worth a ghettorigged slicing and grooving sensor advancement. Perhaps there is an aftermarket ignition system that allows for these mods, in which case it would then be worth it. What we don't need is for newbies like yourself to see this and say "WOW I CAN GET 50 HP!" and then they fu ck it all up and can't pass emissions tests because their engine is out of spec. (if they can even perform the mod in the first place, which a mag racer like yourself probably can't do)
I dont know about you, but I dont usually put BROWN oil into my engine, its usually clean almost clear oil when it goes in.
Old Mar 19, 2002
pichon's Avatar
mag racer? have you ever been to a drag strip (and i don't mean the projects you pass by everyday on your way home). If you have, smart ***, then you'll understand what i'm about to tell you. when i initially posted i said i had done the mod in Mitsubishi Mirage Tecnica, and i said that in, THAT, car the performance improvement was significant. the car i am talking about improved from 16.82 @ 82mph to a 16.43 @83 mph with that mod alone. Now, are you following me, that's a 0.39 improvement in ET (Elapse time, just in case, cuz you don't seem too smart). if that's not significant i don't know what is.
let me tell you something else just becasue i am new to this site doesn't mean i am a "newbie" to the world of cars and much less to the world of racing. i've been a local drag racer for about 5 1/2 years. currently I am racing a 1968 Camaro. A car which I tune and drive. it runs 8.30's @ 169mph. My NHRA competion license number is 280-B, look it up. How fast have you gone??
OHH, by the way, my 2k1 civic DX has already run 15.96 @ 87 mph. How fast is yours? [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Mar 19, 2002
avenger's Avatar
for the last, fu cking time "he who claims to be a drag racer yet cannot spell timing" or read the post above his...
and dont bother me again with a pm to see your reply.
Old Mar 19, 2002
pichon's Avatar
temper, temper[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
i am disappointed, i thought we could be friends[IMG]i/expressions/face-icon-small-sad.gif[/IMG]
Old Mar 19, 2002
avenger's Avatar
[IMG]i/expressions/beer_yum.gif[/IMG]
i own a 68 chev c10 with a 327 running fuelie heads... torque beast
its no 8.9sec camaro though
Old Mar 19, 2002
pichon's Avatar
not bad
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Groundhog66
Sep 16, 2015 07:59 PM
