Loud Grinding Noise Rear of 98EX
Old Sep 17, 2011
mstang1988's Avatar
mstang1988 is an unknown quantity at this point
Ok, I replaced the rear wheel bearings thinking that they were causing the loud grinding noise I'm having. No such luck, it didn't fix a dang thing. What else could be causing the issue?
Old Sep 17, 2011
lazlong's Avatar
Re: Loud Grinding Noise Rear of 98EX
Rear brake dragging? Lift the back of the car and turn the wheels by hand to see if they move freely.
Old Sep 18, 2011
Zeferint's Avatar
Autocross Padawan
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
How does the car handle? Could you be a little bit more specific?
Old Sep 19, 2011
mstang1988's Avatar
They seem to move freely but there is some noise coming from them. I didn't notice the noise until after adding the drums back onto the car.
Old Sep 19, 2011
mstang1988's Avatar
Umm, the car seems to handle fine. I wish I could be more specific, however I don't know how to accurately describe the noise.
Around 40-50mph the noise really starts to pick up. It sounds very similar to a wheel bearing going bad and appears to be coming from the rear of the car. Both rear hubs were replaced this weekend and ruled that out.
Tires are el cheepo models from discount tires but were not originally this noisy so I suspect it is not them.
Rear suspension is not in good shape and needs to be replaced. It's leaking etc.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
sk8ermommie
Jun 9, 2015 10:41 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
Sparty
Nov 15, 2001 04:55 PM
