Help Changing IM Gasket on a Y7
Old Sep 11, 2011
bfairweath's Avatar
bfairweath is an unknown quantity at this point
Anyone change an intake manifold gasket on a Y7? It looks like I can take the 8 or so nuts off the studs in the head and just slide the whole intake back without disconnecting anything else (there might be one more rigid bracket). True? I don't want to get in over my head and have to start removing fuel lines, fuel rail, injectors, etc.
I'm changing it because of another poster that said it can be a cause of air bubbles in coolant. His was leaking at the coolant bypass near the intake for cylinder 4. Also, I was hearing a sound that sounded like an exhaust leak under slight acceleration. I tightened up the nuts a bit and the sound went away! Still have the bubbles, so I want to change the gasket.
Any help for anyone that's done it would be appreciated.
Old Sep 11, 2011
lazlong's Avatar
Re: Help Changing IM Gasket on a Y7
Also, MelJ has a service manual download in his sig.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Mercilus
Jun 7, 2015 10:00 PM
brian257
Jun 4, 2015 08:17 PM
Tim1959
Jun 3, 2015 08:15 PM
mrohitredd
May 28, 2015 10:03 AM
