Question about main relay 98 dx
Old Jun 5, 2011
karizzle's Avatar
Pinkslip Racer
karizzle will become famous soon enoughkarizzle will become famous soon enough
Long story short I have a dx coupe swapped b16. p28 ecu. Recently the car has been randomly stalling out and wont restart until i wiggle around the ecu wires
one thing i noticed when i wiggle around the wires or ecu the main relay clicks. i can make it click infinitly as long as im wiggling the wires, which i dont THINK is normal
is it? if not, is it safe to say i have a cut//messed up wire somewhere between the ecu and main relay?
if it is normal then...anyone have a suggestion as to why my car has been intermittently stalling? i have managed to make it stall by shaking around ecu wires and at the same time, able to make it start when it just turns over by playing with the ecu wires
Old Jun 6, 2011
lazlong's Avatar
Re: Question about main relay 98 dx
Yeah, it shouldn't be doing that. You have an open somewhere. Check the harness really good, especially where it goes thru the firewall and the wires going into the ECM/PCM connectors.
Old Jun 7, 2011
karizzle's Avatar
Pinkslip Racer
thank you for confirming that
+ rep
Old Jun 7, 2011
lazlong's Avatar
Fix that wire/connector and do a wire tuck ASAP if you haven't done it yet.
Jonnie.
Jan 13, 2019 11:21 AM
Wild Cranker
427
Jan 28, 2016 06:49 PM
Black91civic
Jun 6, 2015 08:15 AM
jetcare101
May 8, 2015 01:33 PM
BREADFAN
Apr 15, 2015 08:58 AM
