water pump
Old May 21, 2011
t4rboy's Avatar
t4rboy is an unknown quantity at this point
water pump
So I'm learning that the water pump on my friends 97 ex is behind the timing belt. We think it is starting to go out. I have no idea how to replace it. I have a fsm but it is missing that section (the fsm was downloaded). How do I change it? Do I have to remove the timing belt? Its not overheating yet but the temp is getting above normal. Its not the thermostat but I am gonna replace that soon just to be safe. The only experience I have with honda water pumps was on a 77 accord. Any help is appreciated
Old May 21, 2011
lazlong's Avatar
Re: water pump
Why do you think it's the water pump? is it overheating? If it is, read this first: https://www.civicforums.com/forums/3...reference.html
If you change the water pump you need to change the timing belt also as the labor overlaps a lot. You'll definitely need the crank holder tool and a big breaker bar and a big *** cheater pipe to take the crank pulley bolt off. Or a 1" drive impact will do it most of the time. If it's overheating 'cause of a bad headgasket then you need to change the timing belt and water pump anyways as you have to get the timing belt off to change the headgasket.
You have a PM.
Old May 21, 2011
t4rboy's Avatar
Re: water pump
I run toyota 1st gen 4runners so im going by experience with them. When they over heat its normally the water pump (they have a weep hole to let you know their bad). or its the thermostat. For me this is a guessing game. I dont wanna touch the timing belt if I dont have to since a shop just replaced it 5 months ago but they didn't do the water pump. I just want to know how to do it just in case
Old May 21, 2011
Re: water pump
hondas have different ways to overheat than toyotas - read link provided
Old May 22, 2011
BlueEM2's Avatar
Whachya lookin at?
Re: water pump
Not too often you hear of water pump failure on this thread but it does come by from time to time... read the above thread like others have said. Tons of good info in there.
Old May 22, 2011
t4rboy's Avatar
Re: water pump
Thanks for all the help. I'm gonna replace the thermostat today and go from there. if I do gotta change the water pump I think I'll change the head gasket since I'll be that far into it anyway.
Old May 22, 2011
MindBomber's Avatar
Live for the Twisties
Re: water pump
People tend to opt for the cheapest maintenance possible, so although the car has probably had at least 2 timing belts I wouldn't be surprised if it were the original water pump.
civic98?
Aug 13, 2015 01:32 AM
USCGBM
Aug 12, 2015 04:22 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
mrwhos
Aug 11, 2015 02:03 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
