My 97 civic won't start:
Old Feb 25, 2011
Ek787's Avatar
wildchild787
Ek787 is an unknown quantity at this point
I think it mite be my clutch switch ......is there any way to by past it ???
Old Feb 25, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Re: My 97 civic won't start:
Get up under the dash there will be a clutch switch you can bypass it 1 of 2 ways, 1 is to use a paper clip and insert either end into the back of the plug that is facing you, this will bypass it to test and see if that is what is causing the problem, the second is to cut the wires, strip some casing off and connect the 2. I would test it using a paper clip first before doing that though. Describe the symptoms more, does it attempt to turn over at all or is it just dead in the water no click or anything when you try to start it?
Old Feb 25, 2011
Ek787's Avatar
wildchild787
yea ,its just dead .... all i hear is the main relay & the fuel pumping......i had a viper alarm on it but i took it out cause i thought it was the C.O.D(cause of death)lol
Old Feb 25, 2011
Ek787's Avatar
wildchild787
i'd tried the paper clip..and nothing happen what else could it be..
Old Feb 25, 2011
Newfiedan's Avatar
well there may be a starter kill relay installed with the viper alarm that can stop the car from attempting to turn over, do you know if there was one installed with the alarm? Short of that I would say check all fuses, including the ones in the engine bay and make sure that all battery terminals are clean and tight, same for chassis and engine grounds, then move onto looking at the starter solenoid. You can test that with a jumper wire from the + terminal to the + activation terminal on the starter, should be a small nut holding it on and a 14 gauge or smaller wire. You have to make sure that the paperclip is touching off the bare metal clip for both sides of the clutch switch to bridge it successfully. Do you have a 12 volt test light by chance?
Old Feb 25, 2011
Ek787's Avatar
wildchild787
i took the alarm off so thats not the problem .. the starter is not the problem either cause id jumped it already and the car started fine.. is there a started relay for a 97 ek and if there is where is it located @????
Old Feb 25, 2011
Ek787's Avatar
wildchild787
btw, i dowmloaded the manual u posted but it didnt let open the file
Old Feb 25, 2011
Newfiedan's Avatar
you need to unzip it using winace or some program like that and you need adobe acrobat reader for it since its in pdf format. The relay I am refering to is the one that a lot of alarm installers will add that is inline with the starter wire on the ignition switch, they put it in there so the alarm can kill the starter output when it is armed and disarmed when you remove the alarm you may have missed the wiring for that. Under the steering column look for the ignition harness there are 2 bundles attached to the column using a white zip tie, see if its been cut and if they added a starter kill relay it may be in that area.
Old Feb 27, 2011
Ek787's Avatar
wildchild787
I replace the ignition on it so it's not that...so where's the starter relay located at cause it has to be that..I know is under the steering column but where exactly????
Old Feb 27, 2011
Newfiedan's Avatar
This was in my previous post you must have missed it.
Old Feb 28, 2011
Ek787's Avatar
wildchild787
i'm sorry but i must of wrote it this wrong cause i meant to say ignition harness its been replaced already the alarm is completely unistalled even the starter kill relay...and no there is no cut wire.....
Old Feb 28, 2011
Newfiedan's Avatar
then there has to be a cut or open wire somewhere along the wire for the starter, its the Black/White wire in that harness. I would try unplugging the clutch switch 1 more time and sticking the paperclip into that female end to give that 1 last check prior to going futher.
Old Mar 1, 2011
Ek787's Avatar
wildchild787
i found the problem...it was the relay.......................................
for those of u with the same problem i will post a image later on today
Old Mar 1, 2011
Newfiedan's Avatar
glad you found the problem.
Old Jan 20, 2012
glenscott's Avatar
glenscott is an unknown quantity at this point
i know this thread is a little old, but the paper clip overide worked for me! (i used a bent keyring) thanks alot!
vtec92
May 4, 2017 03:20 AM
usajags84
May 10, 2015 08:11 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
STYLIN2K2
Mid West
Nov 8, 2001 02:18 PM
