tranny problem: i wont go into reverse
Old Feb 17, 2011
Ek787's Avatar
wildchild787
Ek787 is an unknown quantity at this point
IT WONT GO INTO REVERSE:
1-5 goes in fine reverse goes in half way, i tried jamming it but nothing................
i even changed the shift linkage................. im going crazy
Old Feb 17, 2011
Re: tranny problem: i wont go into reverse
Try shifting into any forward gear first, then go into reverse.
Old Feb 17, 2011
Ek787's Avatar
wildchild787
i tried that already but thanks....
Old Feb 17, 2011
just checking. Maybe a problem internal to the tranny then.
Old Feb 17, 2011
Ek787's Avatar
wildchild787
dats great.....
but it worked fine b4 i install tha new clutch
Old Feb 17, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Just because it worked fine prior to clutch change does not mean that its not malfunctioning now, if it shifts fine into all 5 gears except reverse then its most likely internal in the trans. Sometimes removing and jostling the trans can make a problem that was on the verge of happening show up, I had that happen when I swapped a clutch on an older cavalier. It may be an alignment issue with the arm but I doubt it.
Old Feb 17, 2011
Ek787's Avatar
wildchild787
naw u could be right on that alignment part.. ima double check
Old Feb 17, 2011
Ek787's Avatar
wildchild787
alright so i dropped tha tranny and shift it by hand ....it works but y didnt it work when it was on
Old Feb 17, 2011
Newfiedan's Avatar
Improper torque specs on the linkage, shift linkage alignment, worn bushings in the shift linkage, bent shift linkage could be lots of reasons.
Old Feb 17, 2011
Ek787's Avatar
wildchild787
what r the specs for the linkage?
Old Feb 17, 2011
Newfiedan's Avatar
download the pdf manual I posted the link for on the 6th gen main page.
Old Mar 24, 2011
specialized7's Avatar
specialized7 is an unknown quantity at this point
i had this same problem today. It wouldnt shift into reverse. I pushed the car backwards a foot and then it shifted fine. hasent done it since.
velozp
Dec 13, 2015 11:28 AM
mistahlorax13
21
Nov 18, 2015 12:47 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
