catalytic converter
catalytic converter
Hi I was hoping someone could give me a little advice.
I have a 2000 Civic. I had a cracked exhaust manifold, fixed with after market parts. Then after about 2500 miles the check engine light came on. I took it to the dealership, and they are now telling me that the code indicates that there is a problem with my catalytic converter. They said that this may be due to the after market parts, and that they may not be compatable. They said that I need to replace the entire manifold because the cat is part of the manifold. Just curious if this makes sense, and if the problem is due to the after market parts, will this continue to happen once the cat is fixed.
Thanks for any advice.
Re: catalytic converter
You should have an extended warranty on your cat, that honda should have replaced for you in the first place.
Aside from that, the cat is part of the manifold as they say, and if the cat goes out, the whole thing needs to be replaced. You can swap your exhaust to the EX exhaust if you want, but you'll need everything from the manifold back, which makes sense only if you want to do an aftermarket exhaust or can find a EX exhaust for cheaper then the price of replacing your stock exhaust manifold (with the built-in cat)
The link in my sig to the exhaust swap will give you a general idea... you have a 6th gen, the write out is for a 7th gen.. but its mostly the same to my knowledge
ext warranty is only 8 yrs/80k miles on cat. im guessing the aftermarket manifold did not have the cat built into it or what?
Thanks very much for the input, I appreciate it. So if I get this right you are saying that if I switched to the EX then the cat isn't in the manifold. Also do you think that the car would pass an emissions test?
Correct- cat isnt in the manifold with the EX... an as for emissions, you can probably pass by just putting a spark plug non fouler on your secondary O2 sensor to move it out of the exhaust stream to get better readings, unless the sensor is faulty in the first place... other then that, you should pass a simple odb2 emissions test, but in actuallity your car would still fail (O2 sensor nonfoulers are a band aid solution to the problem, not a true fix)
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
Touge
Sep 18, 2015 12:13 AM
