Sub and Amp install problem. Help!
Old May 24, 2003
R1Style's Avatar
Unhappy Sub and Amp install problem. Help!
Ok... my deck has two pre outs on the back of it.
One is for Front Speakers and the other is for the Rear Speakers.
I trying to hook up my sub and amp but when I run the RCA cables through the Rear Speaker pre-outs... I get no sound. Same thing when I run it through the Front Speaker pre-outs. I called a guy at Future shop (Mobile install) and he said it should work running them through the Rear Speaker pre-outs but I'm still having no luck. Can anyone help me out?
I just bought this amp used... could it be the amp? Is there any way to test it?
Thanks in advance
Old May 24, 2003
ZSKCivic01's Avatar
Extreme Member
ZSKCivic01 is an unknown quantity at this point
Thats weird, my alpine unit has 3 pre-outs, front, rear, and sub. Are you sure there is no pre-out for a sub? Usually the rear out is just for regular speakers that go in your rear deck.
Old May 24, 2003
R1Style's Avatar
Yeah I'm pretty sure. I have a JVC deck and not an alpine deck. It's the KD-SX780 and apparently only the KD-SX980 has the sub pre-outs.
Old May 24, 2003
AzNmiKex215's Avatar
2k1civic.com O. G.
maybe there is an option in one of the headunits menu to turn on "sub output" or rear output etc
Old May 24, 2003
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
It sounds like the amp to me but there is any easy way to test it. Make sure everything at the amp is getting power (B+, remote) and make sure the ground is good, also make sure the subs are hooked to the amp. When the amp is on, unplug the rca wires from behind the deck and touch the ends between your fingers. Make sure you are touching both the center post and outer conducter. If the amp is working properly you should get a light thump from the subs everytime you touch the end.
I know this method is my no means high tech, but its a very simple method to use when testing an amp.
Old May 25, 2003
LudlamTheory's Avatar
i boogie for the raindrops
to test it plug a walkman or something into the amp to see if you get output
Old May 25, 2003
R1Style's Avatar
Dude you fu*king rock... I'm gonna go try it now... thanks for the tip!!
roverben
Jan 21, 2019 05:16 PM
jru27
Jun 19, 2015 03:51 PM
jbdewitt
Jun 16, 2015 01:36 PM
PimpBot5000
Nov 26, 2001 07:15 PM
ROBREALZCIVIC
Nov 16, 2001 06:53 PM
