Sound Deadening DIY
#121
Rep Power: 0 As far as eDead goes, it's good stuff. Sticks better than some. Great for its cost. If you do use it:
1. Use AT LEAST two layers, in strips, put down at 90-degree angles to each other
2. Plan to get at least 100square feet to do a reasonable job
3. Clean your metals surfaces well (acetone is my favorite)
4. Your car will stink like a freshly oiled-and-paved road for a couple of weeks until the stuff cures and hardens somewhat. A week of hot days with your windows down will speed things up.
#122
Why is my vagina bleeding?
Rep Power: 280 for the engine noise you reccomended this
Cascade VB-TS
will placing it under the hood, and under the dash here
make a significant diff, or do I really need to open up the dash and apply the material everywhere on the firewall to quiet down the interior engine noise.
Cascade VB-TS
#123
Cascade VB-TS
Cascade VB-TS
#124
Rep Power: 199 Re: Sound Deadening DIY
You know what else works really good is the -----> ( LOW ) <---- expansion insulating foam. Cheep as **** but messy have lots of old sheets handy. Well not for the Dash of course. the trunk and pillars more or less. stick it in all the hole in the trunk frame and let it do its thing flush cut the excess and then use what ever material you find suitable for sound damping. I did this and noting rattles. All parts of the trunk sound solid.
#126
#127
Ya I know this is a very old thread, but would some of the new purple spray insulation that you can get at home depot be a good some deadener in areas that you could see?
#129
Rep Power: 291 Re: Sound Deadening DIY
I want the interior engine noise to be quiter as well as googlethe road noise that comes from the rear near the fenders.
#130
Check out the Adhesion... 3 pounds per square inch on plywood. If the surface is dry, free of dirt and oils, should stick more than enough and not come off ever... if you stick it together, it ain't never coming apart.
#131
I suggest using CDL Tiles for most any sound deadening you need done. It can be put on all surfaces of your door and body it works 5x better than Dynamat and half the cost. checkout the link http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
#134
#136
Received 1,450 Likes
Rep Power: 339 Re: Sound Deadening DIY
my best mileage was obtained with stock steelies and car full of stuff - the headlights were pointing to the skies, rear tires 1" inside the fenders. 44MPG. if you are only going highways, the heavier the better. it starts moving, don't wanna stop anymore.
#138
Car Audio Inc
I'm getting ready to sound deaden with Damplifier Pro. I can really only to afford to do a section at a time. Trying to figure out if I should do the rear deck/trunk/trunk lid first or the doors. Obviously I'm eventually going to do both.. I'm leaning more towards doing the doors first to get that enclosure effect for my midbass drivers. What do yall think?
CraigW
08-18-2015 07:06 AM
BootyDo
07-26-2015 10:38 AM
Hqly2001
07-25-2015 05:32 PM
07-12-2015 11:54 AM
