Anyone have a DIY for headunit install...
Old Mar 24, 2003
DMX's Avatar
DMX
DMX is an unknown quantity at this point
I couldnt find it in the DIY section... and i did search but the links didnt work on some posts.
Oh yea.. anyone know how to take the headunit out without taking the whole console out? I heard that if you already have an aftermarket HU you dont have to take the console out.
Old Mar 24, 2003
DMX's Avatar
DMX
I couldnt find it in the DIY section... and i did search but the links didnt work on some posts. And is the search slow as hell or is it just me?
Old Mar 25, 2003
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
if you have a headunit that was just mounted in the cage and not ISO mounted, then you can just slide the headunit out of the cage with the little keys that came with you headunit. otherwise you need to remove the whole radio/ac pod to remove the headunit if you ISO mounted it
Old Mar 25, 2003
MRB068's Avatar
MRB068 is an unknown quantity at this point
Angry Help removing head unit
I can't seem to get my head unit out. I looked at the diy that describes how to do it, but I can't seem to get the plastic peace that surrounds the head unit and ac. It almost seems as if it is screwed on some how; right above the flasher buttion. I have tried pulling on it but it just does not want to come out. Is it possible that it is screwed in or do I need to pull harder. Acording to the Diy it is connected by five clips. Any thoughts?
Old Mar 27, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
MRB068-- Are you trying to pull out your Factory head unit or a after market one? you shoudlnt have to pull out the AC console if your removing the factory one and I don't think you should have to pull it off to remove an after market one either.. my after market cd player just slides in and out.
Old Mar 27, 2003
MRB068's Avatar
head unit removal
I was trying to pull out factory head unit. I figured it out though thanks.
Old Mar 27, 2003
greggdogg's Avatar
greggdogg is an unknown quantity at this point
If you feel like telling us how you figured us out, please let us know! I'm interested.
Old Mar 28, 2003
MRB068's Avatar
How to remove head unit
I followed these directions. At the part that directs you to push from the inside, the first time you remove it you have to push kinda hard after the first time it gets easier.
http://www.7thgencivic.com/modules.p...howpage&pid=50
Old Mar 28, 2003
greggdogg's Avatar
That works for the 01-02......But not the 03 LX/EX. Anyone got a DIY on those?
Old Mar 30, 2003
zero2seven's Avatar
zero2seven is an unknown quantity at this point
when you pull out the center console behind the radio there should be two 9/16" nuts. Undo those and then push the back of the radio and pull the front. BE CAREFUL when pulling on the front. You need to pull and push pretty hard the shourd itself is held in by clips. Let me know if it works or not.
Old Mar 31, 2003
outdrsmn80's Avatar
outdrsmn80 is an unknown quantity at this point
I just did mine a couple of weekends ago. You need to be careful of the clips that hold the radio/ac/vent assembly to the dash. I lost 2 and had to swipe them from the cigarette lighter piece.
Ziggy1999
Oct 15, 2015 07:56 PM
General DIY
Sep 25, 2015 08:02 PM
meicalnissyen
Sep 25, 2015 12:12 AM
speedlever
Sep 24, 2015 07:18 PM
henrytn
Aug 11, 2015 10:01 PM
