Car Alarm and remote start questions
Old Mar 16, 2003
blazed870's Avatar
blazed870 is on a distinguished road
Question Car Alarm and remote start questions
I am looking to replace my factory alarm system. I am thinking of going with the Python 1500ESP made by DEI. It comes with the remote start and I was wondering if anyone has had troubles with the remote start and how they like it. I also want to get the window roll up modules but I got quoted $300 for all four windows on my sedan. That seems a little pricey considereing I can get the rest of the alarm for a total of $350 installed. Does anyone know how hard it would be to install the window roll up on my own?
Old Mar 16, 2003
WhiteRabbit's Avatar
if you have installed yrou own radio (done the wiring) the power windows is like teh next level up. you have to tap into the neccesary wiring, rather than plug and chug, you have to doublecheck the wires rather than match up the colors, and you have to hunt down the actual windw wires.
otherwise, its pretty much exactly the same. like 8 wires per window, looking for inputs, outputs, most of the wiring is done by the brain.
i fyoru fealess around wire bundles itll be a snap!
Old Mar 30, 2003
zero2seven's Avatar
zero2seven is an unknown quantity at this point
Yeah it's not that bad, you actually can get a wireing diagram for our car at DEI's website. with that it will be a snap.
Old Mar 30, 2003
Niloc's Avatar
Niloc is an unknown quantity at this point
$300??? That’s ridiculous I think the module is about $70 a peace ( price depending on the module they are using)and you would need 2 of them for 4 windows. The install is definitely easier than putting in the alarm system. The only hard part is you might have to take off one or more door panels.
Old Mar 31, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Where on DEI's website can you get the diagram for our car? I only see guides with diagrams to the module harnesses, but not our in-car wires.
Old Mar 31, 2003
zero2seven's Avatar
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2002 / Security
[PRINT THIS PAGE]
12volts white + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Power Lock white/blue - gray plug above drivers kick
Power Unlock white/green - gray plug above drivers kick
Lock Motor yellow/black back of the fusebox
Notes: In the top left plug.
Unlock Motor yellow/green back of the fusebox
Disarm Defeat yellow back of the fusebox
Parking Lights+ red/black back of the fusebox
Parking Lights- blue factory alarm plug
Notes: The factory alarm plug is a green plug above the drivers kick panel.
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger - factory alarm plug
The drivers door trigger is green, front passenger door trigger is lt. green/red, and the rear door trigger is green/white.
Dome Supervision comes on with unlock
Trunk/Hatch Pin red - factory alarm plug
Hood Pin none
Trunk/Hatch Release none
Power Sliding Door
Factory Alarm Arm none
Factory Alarm Disarm none
Disarm No Unlock none
Tachometer blue test connector
Notes: It is a 2 pin plug to the passenger side of the battery.
Horn Trigger orange - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer By Pass : This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U.
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
mistermenphis22
Apr 3, 2016 08:06 AM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
carhag2000
Apr 25, 2015 01:33 PM
Linda0818
Apr 23, 2015 11:30 AM
dano2005
Apr 14, 2015 01:58 AM
