High Pitched Buzzing Sound
Old Mar 24, 2003
jongreenway's Avatar
jongreenway is an unknown quantity at this point
I have 6 neon rods wired in my civic. They are all wired to the same power source, and to a switch. Everything worked fine after the first 2 rods were installed, and then after I installed the other 4 rods, I would sometimes get this little little high pitched noice when they are on. It's hard to notice, but when I turn the lights on, then off I can tell that there is a noise. Can anyone help?
Old Mar 24, 2003
Ed's Avatar
Ed
do you have a system as well? that sounds like a problem peopel get when they install amps, alternator whine. where is the sound coming from, the speakers?
Old Mar 24, 2003
No I don't have a system. The sound isn't coming from the speakers, it's really hard to tell where it's coming from.
Old Mar 24, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
neons do that. not much you can do, except turn the stero up louder
Old Mar 27, 2003
CiViCrAcEr2003's Avatar
CiViCrAcEr2003 is an unknown quantity at this point
Is the noise comming from your speakers? or from the neons themselves... if its comming from your speakers you might try moving the power converter (usually is inside the cig. adapter) I ended up running the wires into my engine bay and sodered wires to the prongs on the cig adapter and went from there.. i'm sure there are other ways of going about this but thats the only thing i could think of at the time. good luck.
Old Mar 27, 2003
THe noise is coming from the neons themselves. If I put a magnet near it, the sound gets louder.
Kaelin
Jun 19, 2015 04:19 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
Bradel26
May 30, 2015 10:24 AM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
godka0s
Nov 8, 2001 07:16 PM
