ahhh... I hate my ice
Old Mar 9, 2003
justheman's Avatar
justheman is an unknown quantity at this point
well ive been working on my system and I got really stoked today when i bought some type r components... 6.5 for the front and the tweets well... I come to realize that the 6.5 wont fit... what the hell do I do?!?!? or am I screwed...
-Justin
Old Mar 9, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
custom it...... u can try to get sum wood panels and cut and screw the 6.5 on... and
drill them into ur door.... but than thats a little to much work and risky in my sense....
So sell them... and buy the right size
Old Mar 9, 2003
WhiteRabbit's Avatar
get a piece of MDF, or particle board, anything really. doesnt need to be too thick, but thcik enough to mount the speaekr solidly. grab a drill and drill a hole in teh door, the size of yrou bolts. its not difficult at all, make sur eyour window is up [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
id put like 2-3 screws into the wood, make it solid. of course i already drilled a 6.5 inch hole to mount the speaker into. the outer shpae doesnt matter, as long as the door panel fits back on. then you can screw yoru speaker to that wood, ight hace to drill throuh the door again, for those screws[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
but seriously, if you are affraid of drilling into yoru door, go to tru value and buy a sheet of thin thin sheet metal and try drillign a couple holes in it. any hardedned bit will work, drilling is easier with oil or any sort of lubricant, even spit will work, but its not totally neccesary, blah, blah, blah.
mostly its jsut common sense! you could stick a 10" woofer on that door spot, its jsut a matter of getting around the small details liek that.
this is what separates the creative DIY'ers from those who are scared to install their own intake. its the common sense, the creativity, and the ***** to just jump in and get yrou hands dirty!
type R's will fit, id bet anything. its jsut a matter of figuring out how! you dont need to sacrifice sound cause your affraid to do some MODIFICATION, its a civic! modification is yrou car's middle name! [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
good luck [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 9, 2003
justheman's Avatar
I love you white rabbit... one more question... I think it will stick out to far and I will have to modify the door panel... what do you think about doing that...any suggestions
Old Mar 9, 2003
Subrage's Avatar
Subrage is an unknown quantity at this point
Quote
[hr]Originally posted by: justheman
I love you white rabbit... one more question... I think it will stick out to far and I will have to modify the door panel... what do you think about doing that...any suggestions[hr]
thats kinda gay, but you shouldnt i dont think those have that big of a basket. if anything you might have to shave some of support behind the waffle stuff
Old Mar 10, 2003
Mystic3030's Avatar
Yup, i'm an A$$hole.
My Quarts are a 7" speaker and they fit with 1" spacers....the door panel does stick out about 1/4 - 1/8 of an inch off the door.....no biggie though, you dont even notice after a while. You can always trip the door with a dremel or tin snips....once it warms up, thats what i'll be doing. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 10, 2003
izod's Avatar
izod is an unknown quantity at this point
I've got XR components in the front, and those things are beheamoth. My doorpanel lies flush because I used a dremmel tool to get rid of that stupid plasic ring on the inside of the panel around the speaker grill. You, too, can do that.
Old Mar 10, 2003
justheman's Avatar
its not really the width of my speakers that is causing the problem its the depth...
Old Mar 10, 2003
doubledeuce2k2's Avatar
rip off the plastic ring on the door panel like everyone is saying and that will help. dremel would work, but i just grabbed onto it with pliers and ripped it off, it was a breeze, and it gives you another 1/2 inch or so of room.
Old Mar 10, 2003
justheman's Avatar
so do I need to cut my door at all... like my speakers are to wide to fit in the hole as it is... like they barely fit at all... and there is about 2 or more inches sticking out...so you think it will be alright?
sorry im so dumb when it comes to audio... im trying... thanks for all the help...
Old Mar 11, 2003
madmax's Avatar
madmax is an unknown quantity at this point
I fit type R 's in the door and they sound great!
The thing is you will have to shave/cut a little bit of the door metal to make them fit , and I also used a 3/4'' MDF spacer.
Can be done!
Well worth the time!
Old Mar 12, 2003
justheman's Avatar
yea I took them into a shop yesterday... and they sound pretty good they are running off my deck which puts out 60 by 4 but im hoping to get a amp later this week...
-Justin
JetsterDajet
52
May 8, 2016 12:11 AM
Tedverseti
Sep 29, 2015 05:41 PM
IronFist
Sep 25, 2015 07:13 PM
chadds
Sep 9, 2015 05:26 AM
JJ291
Sep 2, 2015 11:49 PM
