line output converter
I just bought a line output converter so i can convert the speaker line to the rca. But i can't figure it out. the instructions that came with it are horrible.. There is 4 wires on one end of the box and the rca plugs on the other end and a brown ground wire.
How do i connect this thing to my rear speakers..
any help would be appreciated.
use this for wire colors
what your going to do is go under the rear deck and find these wires. you will to splice the 4 wires from the line output converter (LOC) to the rear speaker wires. Phase is important so be sure that the positive speaker wire goes to the positve on the LOC and just match them up. i had to splice speaker wire into the rear speaker wires, then go to the LOC because the LOC wires were not long enuff. the brown wire is a ground. this is for if you install the LOC and find your getting alot of engine noise or have a system with a floating speaker ground (which you dont) so you probly wont need the brown wire.
JMKendrick
Sep 16, 2015 06:17 PM
powman02
Sep 15, 2015 07:38 PM
tomas6791
Sep 11, 2015 06:47 PM
Bricoleur
Sep 9, 2015 12:23 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
